Tacho Not Working Right
  • NOBY
    • Jun 2004
    • 26
    • UK
    HI THEAR MY TACHOMETER SEEMS TO BE PLAYING UP"" IT WORKS FINE OVER 2000 RPM BUT ON IDLE READS ZERO"" IT WAS FINE LAST WEEK BUT NOW GOD NKOWS
    CAN YOU HELP""??
    CHEERS RICK IN THE UK
    ITS NICE TO BE IMPORTANT"
    BUT MORE IMPORTANT TO BE NICE"
  • strom
    • 1577
    • Slovenia, EU
    AFAIK the tach drops to 0 when there's a charging system problem. Check voltages... when the bike is running.
    LP
    • NOBY
      • Jun 2004
      • 26
      • UK
      TACHO
      FUNNY YOU SHOULD SAY THAT BECAUSE I AM HAVEING PROBLEMS WITH CHARGING WHEN LIGHTS ARE ON""
      I HAVE HAD IT CHECKED WHEN RUNNING AND TOLD THAT ITS CHARGING CORRECT
        Q & D charging test
        Hi Noby,
        for a quick & dirty charging check, point your headlight at a wall, garage door, whatever; mebbe 10 feet away (after dark works best.) If the splotch of light brightens as you rev the motor up from idle, it's charging. If it don't, it ain't.
        Fred Hill, S'toon.
        • NOBY
          • Jun 2004
          • 26
          • UK
          tacho
          will have ago cheers
          • noeleo
            • Aug 2004
            • 52
            • Batesville, Arkansas
            Re: Tacho Not Working Right
            CAN YOU HELP""??
            OK, so I've tried all the "fixes" listed, and mine just isn't right, yet. At idle, it seems to work fine, but when revving the engine steadily, the needle fluctuates wildly. Any more suggestions? Thanks
            Midnight Rider
            1980 XS1100LG
            Intruder Alert!!!
            2002 Suzuki Intruder VS800GL
            XSive rules. Ride it like you stole it, unless it's mine. Then just PUTT, PUTT, PUTT!!!
            Happy XSing
              connections?
              Hi Noeleo,
              what cured my tach was pulling the connectors apart, applying dielectric grease and then snapping them together and apart again several times to clean the contacts as there's no way I can see to get at those teensy little prongs & sockets directly.
              My XS11SG has the two tach connectors in the headlight shell, I do believe that they are hidden elsewhere on the Standards.
              Fred Hill, S'toon.
              • xs1100yam
                • Apr 2004
                • 59
                • Paris (France)
                Hi NOBY
                In fact, the tacho is a frequencymeter; it shows frequency of AC comming from the AC generator (AC generator being on the crankshaft, frequency depends of engine RPM)
                With your symptom, no AC when idle : the regulator is faulty (regulator is in the rectifier module )
                XS 1.1 '83 German model
                XS 1100 '81
                XS 750 77 Work in progress.
                XS 500 76 Restored
                XS 250 77
                XS 360 to be restored...
                TX 750 '73
                GTS 1000
                FJR 1300 (daily use)
                • sksxs1100
                  • 331
                  • Bridge city,TX (Beaumont area)
                  at one time i had the freq for each 1000 rpm.. i can get it again as we have all the goodies at work to do it with
                  Shawn
                  78 XS1100E "Black Rat"
                  78 XS1100E Parts
                  www.hotrod1972.com
