I'm a first time poster and XS owner, (1980 1100 SG) and I am not real familiar with carbs and the like but decided that it was about time to learn so when I thought the bike was running a little rough I tore apart the carbs, cleaned them and reset the floats, which had an inconsistant setting and were set at a measurement greater than the clymers manual said they should be. Also found out that the main jets were 110's all the way across which is incorrect for this model but left them as they were for the time being. Put it all back together, took it for a test ride, and the bike ran terrible at the start or low end of the rpm scale. Then would seem to catch and just about leave me standing on the street!
Did I set the floats too rich and need to reset them? I didn't record their measurement when I reset them but I did reset them to 23 mm and I am geussing that they were at least 26 or so. It has always run a little richer than I thought it should and I am sure at least two of the jets should be bigger. Am I correct in my geuss?
"triple clean") use the breadstick tie to eyeball synch them to get them close.
I didn't completely take them off the rack but I did remove the diaphragm and needle jet, floats and float needles, float needle seats, main jet, and air jet. I didn't remove the idle jets because I was a little afraid to mess with something that looked like it was supposed to be permanent. I did find crud in the float bowls. I did use the bread tie pre-synch method to synch the carbs before I put them back in. It also seemed to sound better to me while it was idling. It is firing on all cylinders, and I run a stock 4 into 2 exhaust. It really only seems to have a problem when I initially put a load on it. Got a sprinkler system to fix and a couple of honey do's to take care of so I won't get to it untill tomorrow but I'll let you know how it turns out.
