I'm a first time poster and XS owner, (1980 1100 SG) and I am not real familiar with carbs and the like but decided that it was about time to learn so when I thought the bike was running a little rough I tore apart the carbs, cleaned them and reset the floats, which had an inconsistant setting and were set at a measurement greater than the clymers manual said they should be. Also found out that the main jets were 110's all the way across which is incorrect for this model but left them as they were for the time being. Put it all back together, took it for a test ride, and the bike ran terrible at the start or low end of the rpm scale. Then would seem to catch and just about leave me standing on the street!
Did I set the floats too rich and need to reset them? I didn't record their measurement when I reset them but I did reset them to 23 mm and I am geussing that they were at least 26 or so. It has always run a little richer than I thought it should and I am sure at least two of the jets should be bigger. Am I correct in my geuss?
