This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
Swap gauges with known working ones, if they then work on the suspect bike, then you know it's the OEM gauges. If you get the same bad readings, then could be speedo gear, cable? Could be bad charging circuit?
79SF "The Teacher" . . .basket case! History shows again and again,
Originally posted by ae7f I cheated and got the bike out on the freeway between offramps. The speedo did register 70mph but it gets up to it very slow. Perhaps a cable lube?
Tach still won't climb and stays at around 4k.
Ben
The both probably need to be cleaned and relubed. The problem is doing this without wiping out the ring and glass.
