This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
don't worry about that,it is only the outside,inside they are like new ,as long your bougie is looking the rigth than it is all well.
xs1100 black 78 2h9 on the road
xs1100 red 79 special with sidecar running on LPG and gas!
xs1100 silber 79 2h9 o t r
xs1100 white 80 2h9 Martini o t r
xs1100 red 78 2h9 Martini o t r
xs1100 black 80 special o t r
xs1100 black 80 2h9 in parts sleeping
xs1100 black 81sport for sale!sleeping
xs1100 silber 81 2h9 i.p. sleeping
xs1100black81midnspeciali.p.sleeping
cbx1000 grey prolink 81 sleeping
cbx1000prolink 83 in parts sleeping
gsx750ex red 81 in parts sleeping
Something I just experienced.... If you replace the carb boots, check the tightness of the fasteners after a couple thousand k's or miles. After syncing carbs the other day, I thought I'd slip an allen key in the carb boot nuts just to check them and most had to be retightened up to 1/4 turn!
Ride smilin'
But like Piet said, they can be cracked on the outside, but still sealed on the inside, dual layered. With it running, spray some starter fluid spray or WD40 around the boots and listen for change in engine, if detected, then they ARE leaking, but if no change noted, then they are sealed. You can pretty them up with spray on Plastidip type rubber sealant!
79SF "The Teacher" . . .basket case! History shows again and again,
