Intake manifolds
  • Filter
  • Intake manifolds
    I found the problem. The intake manifolds are cracked all to
    hell. Does anyone know where I can find a decent used set?
  • #2
    don't worry about that,it is only the outside,inside they are like new ,as long your bougie is looking the rigth than it is all well.
    xs1100 black 78 2h9 on the road
    xs1100 red 79 special with sidecar running on LPG and gas!
    xs1100 silber 79 2h9 o t r
    xs1100 white 80 2h9 Martini o t r
    xs1100 red 78 2h9 Martini o t r
    xs1100 black 80 special o t r
    xs1100 black 80 2h9 in parts sleeping
    xs1100 black 81sport for sale!sleeping
    xs1100 silber 81 2h9 i.p. sleeping
    xs1100black81midnspeciali.p.sleeping
    cbx1000 grey prolink 81 sleeping
    cbx1000prolink 83 in parts sleeping
    gsx750ex red 81 in parts sleeping
    • #3
      Something I just experienced.... If you replace the carb boots, check the tightness of the fasteners after a couple thousand k's or miles. After syncing carbs the other day, I thought I'd slip an allen key in the carb boot nuts just to check them and most had to be retightened up to 1/4 turn!
      Ride smilin'
      Dennis
      • #4
        Ebay and Partsnmore,
        But like Piet said, they can be cracked on the outside, but still sealed on the inside, dual layered. With it running, spray some starter fluid spray or WD40 around the boots and listen for change in engine, if detected, then they ARE leaking, but if no change noted, then they are sealed. You can pretty them up with spray on Plastidip type rubber sealant!
        • #5
          If all else fails. I have an old set cracked on the outside, clean and smooth on the inside if you want them let me know.
          Sidekick1975
          80 XS1100 SG
