Left front Caliper
  • auxtian
    • Sep 2002
    • 136
    • Berkeley, NSW, Australia
    Left front Caliper
    Seems I have to put a bit (lots) of pressure on the left lower fork to get the caliper body not to rub on the disk
    Any answers???
    I've pulled it apart etc but always the same also it's wearing the outside pad on the outer edge of the disk so it isn't touching the inner edge (still stops though)
    Thanks
    CR
    ps forks are not bent and rides OK
  • ratbyk
    • 994
    • Sooke BC
    Left Front Caliper
    You center that caliper on the brake rotor BEFORE you tighten the front axle.
    Put bike on center stand. Unload front wheel with small jack under the engine. Don't lift it off the ground, simply unload the bikes weight off the front tire.
    Loosen the front axle nut and clamp. Shift the wheel Left/right until the caliper is centered. Re-tighten the axel.
    Ken/Sooke
    • auxtian
      • Sep 2002
      • 136
      Can't shift the wheel it is bolted hard to the right leg, the left leg floats and the bottom uclamp holds it in place
      The right caliper is fine it's just the left one. As far as bolting the wheel onto the axle goes I should mention it is a standard H model axle at the bottom of the fork
      CR
      • ratbyk
        • 994
        • Sooke BC
        Centering Left Front Caliper
        Suggest that you refer to page 194, items 3-4-5-6 in the Clymer manuel. It outlines how to center the left caliper on the rotor and how you position, tighten sequence of the front axle
        Ken/Sooke.
        • auxtian
          • Sep 2002
          • 136
          Will check it when I get home but found a couple of things wrong in the Clymers book. Just seems it was not like that before, from memory....but that could be a problem in itself.
          Seems I have to push the leg in a lot harder than I remember to get it to centre the caliper.
          Chris Raith
