SF - SG wheel change(?)
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    Originally posted by Dennyz
    16" verses 17":
    I am a lugger, meaning I don't shift much. I like to stuff the XS into a turn and let the torque pull it out. The XS does this nicely. I notice my Special does this better than my Standard. I felt I scrubbed off speed faster when I let off and climbed out of the turn quicker.
    On the open roads, I felt like I needed to shift the Special to a higher gear. The Standard has noticeably less vibration and engine noise at a given speed, say 65mph.
    If the rear wheels are swapped, make sure to swap the kick stands also, they are different.
    You're comments mirror my observations except that I'm still using the same kickstand on my Mongrel with the larger rear wheel. The center stand however will not lift the rear wheel off the ground.
    I may switch back someday if I score a deal on some 16" tires. ;o)
    Geezer
    • UncleSpot
      • Jun 2004
      • 383
      • Home: Stockton, California Shop: Lodi, California
      there's a difference in stand size(s)??
      Geezer,
      what ARE the measurements in the center stands? I have 2 I got off eBay and I can't use either one with my 4-into-1 that I'm running... If I have the right one (for you) maybe we can work something out; trade, couple of buck$, ...?
      Ron (UncleSpot)
      __________________
      Ron Veil
      <Ron_Veil@yahoo.com>
      1980 XS1100SG
      • Geezer
        • May 2003
        • 2985
        Re: there's a difference in stand size(s)??
        Originally posted by UncleSpot
        Geezer,
        Ron (UncleSpot)
        I'd be happy to trade you but the only difference is in the length of the legs. In your situation, I'd make a custom pipe and muffler set up for those headers to clear the center stand.
        Geezer
