Carb Refurb
  • johnstewart
    • Sep 2002
    • 167
    Carb Refurb
    So I've messed up one of my carbs pretty good ('nother thread).
    I've got a spare set ('79 Mikunis), came off a good running bike, but sitting on my shelf for 20 years (wow).
    I know there was someone on the forums who used to clean/tune these up as a service hobby/business. Is anyone around who still does this?
    I found this: https://www.ebay.com/itm/Ultrasonic-...-/184185469200
    ... but I would like to make sure it's all gone completely through and cleaned, not sure this is adequate.
    Anyone have a recommendation?
    79 XS1100SF
  • johnstewart
    • Sep 2002
    • 167
    And if I'm going to f*** it up myself, this is the kit to get?
    https://www.mikesxs.net/keyster-prem...t-xs1100f.html
    79 XS1100SF
    • sethhope
      • May 2016
      • 226
      • Springfield, MO
      Kit looks good, but you'll also need diaphragms and plungers for the top end if you have some sticking. Where are you located? If youre close, i could assist with carbs.
      1979 XS1100F "Roxy" (my first bike ) - '91 Suzuki GSX1100 Fairing, BMW bags, Cheap ABS Trunk, aftermarket cruiser seat, MAC 4-2 exhaust, Heavy Duty folding kickstart, XS11 Special signals and gauges, Blade Fuse Conversion, Dynacoil Greens w/ ballast bypass, SS brake lines
      • johnstewart
        • Sep 2002
        • 167
        Thanks, Seth! Are those parts available or unobtanium at this point?
        I'm in Madison, WI; where are you?
        79 XS1100SF
        • sethhope
          • May 2016
          • 226
          • Springfield, MO
          Ah im in Springfield MO. A little far. I can help through the internet though if you need.
          As far as the diaphrams, you can get them in a couple places. Just found this on ebay searching for xs11 carb diaphrams
          https://www.ebay.com/i/353119997711?...evt=1&mkcid=28
          The plungers can be cleaned up with carb cleaner or an ultrasonic.
            Be cautious. There are a lot of jet manufactures out there that put out imposter jets. Micunis are the only reliable ones that I know of.
              Very true as Skids has stated. K&L and RD are among those imposter main jets. Mikuni main jets are the ONLY ones metered correctly according to metered size. For example, a K&L main jet metered sizing of 110 is equivalent to a Mikuni main jet of 115-117.5. Been several yrs. ago I sized and compared the two, but you definitely wanna use Genuine Mikuni main jets!.
              • Bax
                • 344
                • Merrimack, NH
                Slide diaphragms for BS34 carbs are available from JBM industries.
                • GLoweVA
                  • Jun 2011
                  • 1957
                  • Virginia Beach, VA.
                  I got a set of these diaphragms from Ebay just a few months ago and they were a bit thin and were difficult to get on without damaging them, but they worked fine.
                  80G (Green paint(PO idea))
                  The Green Monster
                  Got him in '04.
                  bald tire & borrowing parts
                  Scarlet
                  Got her in '11
                  Ready for the twisties!
                  81H (previously CPMaynard's)
                  Hugo
                  Cold weather ride
                    Hi George,
                    Nice to see you posting again.
                      Have you seen this tech tip? The pix are still there. May find it helpful.
