Building one engine out of two.
  • e30 gangsta
    • Mar 2016
    • 142
    • Lone tree, Colorado
    Alright guys quick question.
    I have a blown motor xs with a 3J6-000101 1980 engine In it.
    I bought a spare 1981 4R0-000101 running engine for it.
    The problem is the 4R0 engine did not come with a timing Advance unit.
    Can I install the 4R0 engine into the 3J6 frame and use the 3J6 tci and timing Advance unit on the 4R0 engine?
    Any help would be greatly appreciated. Thank you!
    80 XS1110 SG, RD400
  • red bandit
    • 970
    • central michigan
    Yes you can.
    79 SF parts bike.
      • 5073
      I agree. Keep the older model black box and older coils as well.
      • e30 gangsta
        • Mar 2016
        • 142
        Well guys thanks for the help. Update bike is running amazing running the 1196 big bore kit and new mikuni rs36's. Seriously they transformed the bike. Thanks again for all the help y'all. Now I have some small questions.
        1. Are the rear turn signals supposed to be on as running lights on the 78? Or do they only turn on when activated?
        2. The stationary pointer was moved by mistake during the build and I want to make sure it's in the right location. Is there a specific way to do this, or is it just setting the piston to tdc on #1 and then moving the pointer to tdc as well? Thanks!
        80 XS1110 SG, RD400
          • 8892
          1. No, rear signals are not supposed to be running lights, on with signal activation only.
          2. Yes, position the #1 piston at TDC compression stroke and readjust the pointer to the 'T' mark.
          • Tonyxs11
            • Oct 2022
            • 271
            • Cumbria UK
            using a dial gauge will give a more accurate measurement for TDC if you have one.
            • e30 gangsta
              • Mar 2016
              • 142
              Yep I have a piston stop and a degree wheel. I need to get a dial Gauge. Good idea thanks y'all!
              80 XS1110 SG, RD400
              • jshaw010
                • Jul 2024
                • 2
                Love that the rs36s are working well for you. I’m thinking about getting some. Where did you connect your stock vacuum advance line?
