Stuck clutch
  • leggman1
    • Oct 2016
    • 130
    • Winchester, KY
    Stuck clutch
    I started my 81 today and it runs great but the clutch seems to be stuck. When I click it into gear with the clutch all the way in the motor dies. I have tried rocking it in first gear with the clutch in and it wont free up.
    The bike has sat for about 2 years
    81 XS11
    • 7828
    Put the bike on the side stand, remove the clutch cover, pull all the clutch plates out, clean them, and reverse procedure. I just got done doing that to a bike that has been sitting for about 10 years.
      • 3346
      Could be your cable is not traveling fully inside the sheath since it has sat for two years. Or the linkage on the other end is not traveling fully.
      If you can unhook the clutch cable at the lever put oil into the sheath let it soak, put some more in there and see if you can loosen it up.
      Or remove the cable entirely so you can slide it back and forth while you add the oil.
      Could be the clutch plates are froze because of mother time.
      Those are things that come to mind.
      2001 ZRX 1200
      1982 Seca 750
      1983 Nighthawk 550
      • MPittma100
        • Aug 2011
        • 2359
        Stuck
        Warm the bike up. Keep rocking it until it frees up. Not uncommon for this to occur.
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          • 3346
          Good idea, let the oil get up to temperature and heat may be your friend.
          I don't know if this would work... Put it up on the center stand, point it in a direction it can roll forward, click it up into 3rd 4th or 5th gear pop it off the center stand with you in the saddle and see if the forward momentum in a higher gear will help you too.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
            • 8927
            Get on the bike ready to ride, put in first gear. Turn on the ignition and push the starter button. When you start moving and the engine starts, it should quickly free up.
            • leggman1
              • Oct 2016
              • 130
              • Winchester, KY
              I am going to pull the cover and check the plates
              I dont want to do any damage by rocking it
              81 XS11
              • leggman1
                • Oct 2016
                • 130
                • Winchester, KY
                Didnt find anything wrong. Just a bunch of stuck plates.
                81 XS11
                  • 2158
                  You did find something - peace of mind.
                    • 3346
                    Soooooo... Ride report! Come on, tell us that you got it fixed.
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
                    • leggman1
                      • Oct 2016
                      • 130
                      • Winchester, KY
                      I did ride it around my neighborhood and it seems to be fixed.
                      I guess thats what I get for letting it sit for so long
                      81 XS11
                        • 3346
                        Hey look on the bright side, the bike has now told you it wants you to ride it more often! Nothing like being more regular with that.
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
