I'm in the middle of repiping me Octopus and have come across a problem.
I may be thick or just stupid.
On the Octopus there are numbers 1 to 4
1 and 2 are in the middle and 3 and 4 are the outside pipe connectors.
According to the manual octopus connector number 3 connects the fuel pipe to carbs 1 and 2 and the left hand front petrol tank tap connector via a T connector.
Octopus connector number 1 connects the fuel pipe to the left hand rear petrol tank tap.
I've done that no problem.
Now the bit I'm confused on.
According to the manual the fuel pipe from the right hand rear petrol tank tap goes to one of the middle octopus connectors which is number 2 BUT the manual has a arrow pointing to it and calls it number 4 hose.
The fuel pipe from the right hand front petrol tank tap goes to carbs 3 and 4 and via T connector to the outside octopus connector number 4 BUT the manual has a arrow pointing to it and calls it number 2 hose.
Am I right in thinking that the manuals number 2 hose should go to number 4 octopus connector and hose number 4 should go to number 2 octopus connector?
Therefor the rear petrol tank taps go to the middle two octopus connectors and the front petrol tank taps go to the carbs and the outer two octopus connectors.
