Cam Chain wear test?
    Your bike runs; let it be.
    At this point I believe that you should go ride, forget the advice and The Fine Manual and leave complex mechanical concepts and procedures it explains and illustrates like setting the base camshaft, crankshaft, and ignition timing alone
    before you bend a bunch of valves and can't go riding at all.
    This is supposed to be fun and a hobby so go have some fun!
    • dbbrian
      • May 2016
      • 596
      • Stratford, Ontario, Canada
      #62
      Thanks Scott - Ya, bending valves would suck.
      I was filling this tread with questions, exploring, learning...hoping it would help me and others.
      I am with the setiment of leaving well enough alone...the enemy of good is better..etc., etc. There is always more to do on the bike, and its time to ride. (its just in time, here in the land of the great white north).
      Thanks for all the input from everyone.
      Brian
        #63
        I just hope there is no valve interference if the valve/cam lobe clearances get too tight.
          • 3373
          Post #46 looks like the timing wheel is pointed at close to the 20 mark. Post #60 looks closer to 15 like you say.
          With the timing wheel at the same position as post #46 what do your cam marks look like?
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
          • dbbrian
            • May 2016
            • 596
            #65
            In both casesI lined up the intake cam with the dot.
            • dbbrian
              • May 2016
              • 596
              #66
              A running Bike
              Just wanted to close the loop on this thread for now. I put the bike back together and rode it. Runs good, and no leaks
              Thanks for all the help
                • 3373
                Awesome to hear!
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
                  • 1591
                  Brian,
                  FANTASTIC to see your E buttoned up and back in Go Ride mode.
                  Nice Job good to finally have an ACCT too
