XS1100SG which pilot jets
  • mlew
    • Jun 2005
    • 226
    • Apex , NC
    These are the ones I have in my SG MArty.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I have found that the jets in most carb kits for XS11s are the wrong size. I get the best results when using only genuine Mikuni parts.
    Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
    Current rides:
    80 XS1100SG
    82 JX1100
    83 Venture Royale
    86 V-Max
      That’s the size I have. Mine have six instead of eight bleed holes. Thanks!
        Originally posted by BA80
        One other thought, be sure the air bleed holes are clear in the emulsion tubes. If they are blocked, clogged ,you will run rich as well.
        The air jets on the air cleaner side of the carbs too.
        As a part of this, the emulsion tubes are affected by the pressed-in jet in the inlet bell of the carb. Put the carb cleaner straw right up to it and spray. Years ago, I got the new correct Micuni pilot jets and noticed that the outlet holes looked a tiny bit smaller. Could it have been from scouring of the originals? I don’t know, but be prepared to compensate with the pilot screws.
          OK. I replaced the slide needles and the emulsion tubes. I'm now at +- 40 mpg. Thanks all!
          • MPittma100
            • Aug 2011
            • 2359
            Hallelujah! Finally got her done. I know you are elated with that result. Just when you thought it would never happen. Congratulations! Lean and mean!
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              Where did you get these? Were they new and original Mics?
                I bought a junk bike from a shop in North Georgia. The odometer shows 20 thousand something miles. The needles have the correct part number on them for my SG. In other words, I had parts in my stash.
                XJ4Ever.com has reproduction needles for the XS1100SG. He also has the emulsion tubes. That is the only place I have found those parts. So far, everything I have purchased there has been outstanding. I did not want to spend that much money without knowing I had a fix. Luckily, I had spares on hand. I'll be buying them for the next set of carburetors!
                To complete the answer to your question. I believe the needles are $8.95 ea. The emulsion tubes (needle jets) are $24.95 ea, IIRC.
