Anywhere I can get a fuel tank gasket for my 80 SG? It is cracked and not liking that.
fuel tank gasket
fuel tank gasket
1997 Jeep Cherokee 4.5"lift installedTags: None -
Cap gasket-will look on e bay or bike bandit-Mikes XS had dealt with them before1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installedComment
"The Flying Pumpkin"Comment
Years ago you could not even tell MIKES XS you had an 1100 as he wouldn't deal with people that told him that. Been years since I dealt with him. The gasket has 3 screws it looks like holding it on.1980 XS1100 SG
So what am I looking for as far as fitment? would another model be the same? I cant believe Yamaha made specific gaskets for my SG did they?1980 XS1100 SG
New From China $15
You can buy a whole new cap from China for about $15, check e-bay.
If so inclined, you can just pull out the gasket and put it in your OEM cap.
Personally, I have a couple of these Chinese caps on my XS11's (Currently own 5). Most of the caps on my machines were all rusty and crappy.
NO, the quality is not the same as the OEM but it's more than sufficient to hold the gas in the tank and properly vent the tank.
Just my 2-cents.Kurt Boehringer
2016 - FJR1300A - MontgomeryComment
I've often wondered if you can transplant the original lock onto the new tank cap replica, so the key will match.-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65Comment
The fuel cap seal is available OEM. All of the Specials use the same one. XS11, XS850, XS750, XS650. If you buy OEM, it should last 35 years.Marty (in Mississippi)
XS650EComment
Very good to know! Many thanks!1980 XS1100 SG
Hi Mike,
the locks on my original Yamaha & MikesXS replica gas caps all swap no problem
so I'd suppose the lock on a Chinese replica would swap too.
Or there's always plan 2:-
Strip out the replica lock's wards, file the keyslot straight and open it with any key at all. Or a screwdriver.Fred Hill, S'toon
Hi Mike,
I did something similar to an old F-150 back in the day. Eventually the ignition cylinder crumbled and I had to jump it under the hood. I was always a little afraid it was still in gear, but I was also young, cheap, and careless.78 EComment
I ordered the fuel tank gasket on E Bay.1980 XS1100 SG
