new tire WILL NOT fill.
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    It was put on correctly.
    brand new michelin commander II; correct size (100/90 b19).
    leaking out of the rim.
    took wheel weights off to see if that helped...of course it didn't.
    took it to the garage up the street...they couldn't help me. said I needed to use a cheetah to get it on.
    so then I called cycle gear, and I quote: "we wouldn't have any other special tools other than what you have at your house."
    tried the redneck starting fluid trick...NOPE.
    IT'S BEEN TWO DAYS OF TRYING STUFF / BUYING THINGS TO TRY TO GET THIS ON. I'M OVER IT. Anything I can do??? I'm pissed.
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    leaking rim
    (1) the rim is/was cleaned
    (2) slippery soap or another tire mounting lubrication used on the bead
    (3) no damage to rim or tire
    (4) check the air pressure at the compressor
    (5) debris in-between the tire and rim
    I imagine you have done all this so, put a ratcheting tie down around the tire to try and squeeze, expand it against the rim and try again
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
      • 2066
      I have had to put a rope or ratchet strap around the perimeter of a few of my tires to get them to grab the rim enough to start filling.
      If you don't have a ratchet strap, you can tie a rope around the circumference of the tire, and insert a stick under the rope, and twist the stick to force the tire out against the rim.
      • ERM83
        • Apr 2016
        • 314
        • Lehigh Valley, PA
        So, I've officially tried every possible trick you can as of now. no matter what, still an air leak, always on one side. when I try to push to seal it, it doesn't work, or just moves to another spot. the best i've gotten was 5 psi. i'm convinced that this brand new freakin' tire is defective. NEVER had a problem like this.
        79' SF carbs
        MAC 4-1
        K&N Pods
        Accel 3.0 coils
        Tarozzi fork brace
        TC fusebox
        Picture update soon
          • 5062
          It can also help (I think) to pull out the valve core to fill the tire rapidly.
          • ERM83
            • Apr 2016
            • 314
            • Lehigh Valley, PA
            I tried using a heat gun as well...no dice. the tire is SOOOOO close...it just looks off a bit on one quadrant (which I thought would fill in). Is there anything I can use to fill in that gap?? I'm having a hard time believing that the TINY space that's void is preventing this from inflating. there's no leaks in the tire elsewhere at ALL...checked that thoroughly. Just in two small spots in any given quadrant.
            This is going to sound ridiculous (grasping at straws here), but would there be any way that fix-a-flat would help any?? this SUCKS...SO BAD. I was psyched to get that tire on there...
            79' SF carbs
            MAC 4-1
            K&N Pods
            Accel 3.0 coils
            Tarozzi fork brace
            TC fusebox
            Picture update soon
              Sounds like bead isn't totally seating on rim. May try having very ittle air in tire(5psi), then bounce mounted tire as wheel is rotated. Occassionally, this helps to seat bead of tire to rim.
                • 8796
                I took mine one time to an automotive tire shop and the fellas there got the bead seated, I gave him $10 I think. They will have a strong air compressor. What type of air compressor are you using? Small unit probably won't cut it in your case.
                07 Triumph Tiger 1050
                  • 2083
                  ^^^ This^^^ And if that fails then the following will get ya on two wheels again.
                    • 5062
                    I would throw a tube in it.
                    • soccer4m
                      • 694
                      Second that
                      I second trying to Bounce the tire at lower pressure, a lot all the way around, and if you dont want to worry, pop a tube in, or put in 10 oz. of Ride ON tire sealant and balancer in the valve stem, and ride it till it seals. Hope it works one way or another,,,,good luck,,,,Mike in SUnny DIego
                      mike
                      1982 xj1100 maxim
                      1981 venture bagger
                      1999 Kawi Nomad 1500 greenie
                      1959 wife
                        • 7765
                        Take a bit of cardboard and make a "T" shaped cutout that just fits inside the rim. Slowly rotate the rim and see if it's bent slightly at the bead area. If it is always the same side/place on the rim that could be part of the problem. If so, just run a tube.
