XS1100E rear view mirror disassembly
  • XSSIVEUS
    • Jul 2018
    • 91
    • Sheridan, OR USA
    How do you disassemble a stock rear view mirror? I bought a NOS mirror on line, installed it, and after one ride something is loose inside. Sounds heavy whatever it is. I suppose there is a trick unless the glass is glued in place in which case I'm hosed. Any suggestions folks?
    78 XS1100E touring
    78 XS1100E stock
    80 XS1100LG Midnight Special
    83 XV920MK Midnight Special
    83 XJ750MK Midnight Special
    83 RX50 Special
    97 FLHR
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    mirror
    I've saved many mirror parts over the years, do you have a picture of what you have ?
    I may have the exact part, like new or at least one like it you could try taking apart to see how it's done
    So got a pic ?
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • red bandit
      • 957
      • central michigan
      If something fell off on the inside and you can get the mirror part off of the stem you can stick a screwdriver in the back side and push the mirror out of the plastic housing. I've done this before. I've heard some say that you can stick the mirror/housing part in hot water. The plastic expands more/faster then the mirror and it will fall out.
      79 SF parts bike.
        • 8862
        If you need to pry the glass out, carefully do so with a plastic putty knife and by NO means use anything metal or you will looking for another glass, BTDT.
        • XSSIVEUS
          • Jul 2018
          • 91
          • Sheridan, OR USA
          Some good thoughts guys, especially the hot water deal. I found an old beat up mirror in one piece. Will try that approach though I hope it doesn't take more than one assembly to figure this out. Here is a pic of the assembly per one request:
          Billions of happy photos, millions of passionate customers. Gorgeous online photo albums. Protect your priceless memories. Buy beautiful prints & gifts.
          78 XS1100E touring
          78 XS1100E stock
          83 RX50 Special
          97 FLHR
