Mikes XS Fork seals for Special
  • mschor
    • Jan 2017
    • 183
    • West Palm Beach, FL.
    I just took the old seals out, new ones from Mikes XS are not identical. I ordered OEM from Mikes and this is what came. Are these useable? Thickness of original is 9mm, new one is 6mm thick with a tapered lip that makes it about7mm
    81 Special
  • mschor
    • Jan 2017
    • 183
    .....and i didn't take note which way up for the seal and the spacer below it
    81 Special
    • speedlimit85
      • Jan 2017
      • 446
      • Gainesville, Fl.
      In my experience, mikes xs is not exact but usually works.
      Partzilla is genuine OEM and is worth paying more.
      80 G
      • mschor
        • Jan 2017
        • 183
        I'm wondering if that couple millimeters between the top of the seal & the c clip will be a big deal. Anybody know the thickness of the factory seals? Maybe mine swelled over 30 yrs & the Mikes XS ones are actually right?
        81 Special
          • 8891
          The correct size for the Special is 37X48X10.5
          If the ones you have are the correct ID and OD but just too short, they should still work. I usually make a spacer out of PVC pipe to take up any gap between the seal and the C-clip.
          • mschor
            • Jan 2017
            • 183
            Ok, i went ahead and did it , they were super hard to drive in , i used 1 1/2" pvc ground down slightly. I didn't use a spacer, there wasn't much space there maybe because i just drove them down to just below the c clip slot. I didn't want to damage them going too far. Put it all back together and it feels the same!.....as you say pluuuussshhhh.
            I used 15W oil but i didn't cut the springs or anything. Actually threading the caps on was very easy because the springs were only about 1/2" past the end of the tube. I didn't measure the spring length but maybe they're a little worn in. Boiling the old seals in the lowers made it a cinch to pull them out
            81 Special
              • 8891
              Awesome bro, it should ride better too with fresh oil. Good tip on removing old seals. If you have too much dive you can raise the oil level in each fork slightly.
              • mschor
                • Jan 2017
                • 183
                I think I'll do that , it dives a lot
                81 Special
                  • 8061
                  Try setting the oil level at 130 mm from the top with the spring removed and the fork collapsed. That’s the Race Tech spec. Adjust 10 mm up or down from there.
                    • 8891
                    You may want to also use maybe 3/4" long, 3/4" PVC spacer on top of each spring. Make sure to put a washer on both sides of each spacer.
                    • red bandit
                      • 970
                      • central michigan
                      Any idea how many cc's that amounts to? And how many cc's to increase 10 mm?
                      79 SF parts bike.
                        • 2096
                        Vol. of a Cyl.
                        Here ya go:
                        Our volume of a cylinder calculator takes height and radius to instantly calculate your cylinder's volume.
                          • 8891
                          You know Mike, the easiest way is just put air in the front forks via Schrader valve on each cap.
                            • 7816
                            mschor, Just get about 15" of a soft steel rod, bend a 90 at one end and mark 10mm notches down from the top. As jetmechmarty said,"Try setting the oil level at 130 mm from the top with the spring removed and the fork collapsed. That’s the Race Tech spec. Adjust 10 mm up or down from there."
                            This will help some, but the PVC spacer will also help with the sagged springs. Just remember these are 40 year old bikes, with 40 year old suspension technology. It will take work and money to get them close to the newer bikes!
                            • mschor
                              • Jan 2017
                              • 183
                              Thanks for the suggestions! It's true i haven't refilled with air yet, i will do that first...15psi i think? Then if it's still very soft I'll do the 130ml & spacer.
                              On another note, the front axle was very tough to get out and had some rust on it. I'll attach a picture. Is this a big deal? I sanded off the rust and put some lithium grease but i noticed at parking lot speed cornering a little rub on both sides, something feels not 100%. I'm going to remove and look at it again. Brakes aren't rubbing much. There was a washer that dropped as i was removing the axle. I put it between the axle nut and the fork because it was only big enough to fit over the threads, it was smaller than the rest of the axle.
                              81 Special
