Float bowl gaskets
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Float bowl gaskets
    Hey guys,
    How to rejuvenate float bowl gaskets ?
    Soak in fuel, MMO, transmission oil ?
    Has anyone done this successfully ?
    Done };-)
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    I've just replaced them. If they are hard, and they have shrunk, it's not worth the trouble they can cause to try and "fix" them IMHO.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Yeah I've been checking dealer wants $26.99 each, over $50 pr., after market on eBay about $12 for a pair.
      I've 8 pair soaking in MMO just to see what happens ? ? ?
      76 XS650 C ROADSTER
      80 XS 1100 SG
      • MPittma100
        • Aug 2011
        • 2359
        Gasket
        $17.99@ on Partzilla. $19.97 for 4 on EBay. Could not find anyone giving them away?
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          • 1262
          • Peachtree City, Georgia.
          jetsrus.com
          Jeez....
          Just get them from JetsRus.com
          007-990 Float bowl gasket OEM Genuine $3.41
          Just received a set this week.
          KURT
          1982 - CBX1000 - Honda
            Jeez....
            KURT
            Kurt, ha ha ha ha ha ha ha.
            https://www.ebay.com/itm/YAMAHA-XS11...kAAOSwr7ZW8KXF
              Originally posted by BA80
              Just make sure that all of the hole punches are removed. Sometimes they are left in the gasket. One more thing, don't strip the bowl screw holes like I did once.
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                Hey guys,
                Done };-)
                This is what I want to try !
                If I wanted to buy new I would and probably will.
                Got an answer to the original question please reply.
                Thank You, Don'e
                76 XS650 C ROADSTER
                80 XS 1100 SG
                  Just ignore my post as I can't delete it...
                    Hey guys,
                    OK, here is the answer:
                    Buy new gaskets.
                    Sorry, but as the old material ages it get VERY brittle. There is nothing you can do to reverse the process. Trying to "save" them will take you more time and frustration, with the result being parts of the old gasket floating in the bowl.
                    This is my take on it, but I believe it is very close to the truth. I have gasket material from THIS century that is hard and brittle. Why would something 20 years older be any better?
                      Did you post something Sid??
                        Yes it was post number 7 but we were getting off track because he wanted to rejuvenate the gasket rather than get new.
                        • donebysunday
                          • Oct 2012
                          • 1737
                          • New Berlin, Wi.
                          Float bowl gaskets
                          OK, picked up a little tip from the man, William Denton over at the Micapeak Yamaha XS650 list. With the gaskets suspended in a sealed gallon can ( I used an old carb cleaner can and strainer) pint of fuel in the bottom, gaskets in the strainer suspended out of the fuel, sealed the can and now left to fumigate. I'll check in a couple weeks, in the meantime I found this place on eBay, hildebrandtgasketcompany and ordered a set of 4 float bowl gaskets $11.99. This company says they make these gaskets out of high quality gasket materiel.
                          I'll post again in both cases the outcome ?
                          76 XS650 C ROADSTER
                          80 XS 1100 SG
