My nuteral light isn't working. When I touch the wire on the sending unit to ground it works. Any ideas?
Nuteral light switch
There is a plunger in the switch that rides on the shift drum, or shift cam. I have never had one apart, but an educated guess would be that the plunger makes contact with the contacts in the switch, and makes a ground for the light to come on. It's possible that somehow the plunger isn't making contact inside the switch. Remove it, and check the continuity through it with the plunger in both positions.
