Fork seals
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Fork seals
    Bought some things from a guy on eBay and he mentioned he had 5 pairs of fork seals for the XS11. He wants $6+ shipping each pair or he can include them all with my other order for $25 for the 5 pairs and no shipping to me.
    If anyone is interested let me know ASAP at dsundby@wi.rr.com or he will send my other parts and list the fork seals on eBay ?
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • dbbrian
    • May 2016
    • 596
    • Stratford, Ontario, Canada
    As long as they will fit my 78E I'll take a set.
    I'm in no hurry.
    Brian
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Fork seals
      Hey Brian here's a link to one of his auctions for a water buffalo on eBay, contact him through this auction # 232851107934 about the fork seals
      Done };-)
      76 XS650 C ROADSTER
      80 XS 1100 SG
      • MPittma100
        • Aug 2011
        • 2359
        Fork Seals
        Be sure that the seals are oem type. There are aftermarket (cheap) ones that do not seal properly.
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
        • Jerry
          XS & TRUE XJ GURU
          • 3023
          • Elma, IA.
          From past threads, not all 11s use the same diameter fork seals. There is a 1 or 2 mm difference if I recall correctly. Many parts houses get this wrong so you need to check. (Same applies to Tkat's fork brace; different diameters for different fork tubes.) You may want to do a search on fork seals to see past threads on this topic.
          I would verify from the seller what diameter his seals are; should be stamped some place on the seal or on the packaging.
          Jerry Fields
          '82 XJ 'Sojourn'
          '06 Concours
          My Galleries Page.
          My Blog Page.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            forking seals
            I have asked this guy for manufacturer and which models they fit. Partzilla has a different # 3J6-23145-00-00 for Special, includes Midnight, SG, LG, SH LH, (SF is no longer listed but I would think the same seal?) non-Specials E,F,G,H take # 2H7-23145-00 and below that they list # 41Y-23145-00-00.
            He sent this, (cross references to Parts Unlimited FS-031 Front Fork Seals 37mm x 48mm x 10.5mm)
            76 XS650 C ROADSTER
            80 XS 1100 SG
              • 8861
              37-48-10.5 are for the Special. 37-49-8 are for the Standard. The XJ11 uses even a different size.
