Spark plug gap
  • XS 1100 Rick
    • Nov 2013
    • 39
    • Lethbridge, Alberta, Ca.
    Spark plug gap
    Hi what gap is preferred for the 78E Ngk plugs bpr6es Thank You!!
    XS11E 1978
    Past Bikes that I owned
    H1 Kawasaki 500 1972
    CB 750K Honda 1978
    CB 750K Honda 1979
    Triumph 500 Daytona 1968
    Triumph 650 Bonny 1969
  • XS 1100 Rick
    • Nov 2013
    • 39
    FOUND IT .028-.032 Thx
    XS11E 1978
    CB 750K Honda 1978
    CB 750K Honda 1979
      bpr6es
      The correct plug is a bp6es, no "R"! If you run the "R" plugs, you should pull the resistor from the plug caps. The "R" is to keep radio interference down, but it will reduce the spark energy.
      • Blank Slate
        • Nov 2013
        • 393
        • Ottawa, Ontario, Canada
        Hey Driver Ray, where do you buy the bp6es? I tried amazon, cdn tire, napa, I'm only finding the BPR ones. They say it's interchangeable with BP6es. How do you 'pull the resistor from the plug caps'? Does it come off the spark plug or off the NG elbow connector thing?
        My bike wouldn't start for 6 months (ok 4 months were winter) and it's because i had wrong plugs and corrosion in the elbow plug and copper wire. I cleaned that up, put in 4 new bpr6es plugs, and the bike started right up
        Frame: 79 XS1100S
        Engine: 81 XS1100S
        Carbs: 78-79 BS34
        Gf bike: 78 XS650S
        Carbs: 70-79 BS38
          BP6ES is no longer available in the US my bet is that Canada isn't any different. Google "remove resistor from ngk spark plug cap" for instructions on how to do that, it's pretty simple.
            Yambits : for Yamaha bikes You can also just buy some non resistor replacement spark plug caps.
              Been my experience that you can not remove the resistor from the oem caps. At least I have not been able to without destroying the cap.
                One other thing that I thought might be mentioned. Beware of buying plugs off of Ebay. There are many listed as BP6ES and they are mostly counterfeit. ngk bp6es spark plug for sale | eBay
                  I replaced mine. The Honda CB750 coils tat I bought had two caps with elbows for 1&4 and straight caps for 2&3. The elbows came right apart, the straight ones where a different story so I used two of my previous replacements for those.
                    One other thing that I thought might be mentioned. Beware of buying plugs off of Ebay. There are many listed as BP6ES and they are mostly conterfeit. ngk bp6es spark plug for sale | eBay
                    Any way to know which ones are counterfeit?
                    • Blank Slate
                      • Nov 2013
                      • 393
                      the address on the box,
                      the labels on the plugs,
                      and date of manufacture on the plug
                      Frame: 79 XS1100S
                      Engine: 81 XS1100S
                      Carbs: 78-79 BS34
                      Gf bike: 78 XS650S
                      Carbs: 70-79 BS38
                        Very helpful Blank Slate!
                          Yes, this fake crap is scary.
                            • 2117
                            Napa still lists them on their site. Might have to order direct from them.
                              I have a Napa about 2 miles from my house. I get my oil, plugs, and other small "universal" parts from them.
