Oil drain plug and filter bolt
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    What do you guys recommend on these as not to round these off down the line? Closed end wrench or sockets? No problems getting off or on just trying to preventive. Thanks
    79 XS11SF
    • 5062
    Concerning the oil filter bolt: Good quality 6 point socket and if you have any doubts, grind the rim of the socket to get rid of any rounded portion from the manufacturer. If you don't doubt that it come loose, no grinding needed. People tend to overtighten these things. It is the 2 o-rings that make it seal! Never use a 12 point or an open end wrench on it, at least that is my advice...
    • dbmb0416
      • Jun 2015
      • 128
      • Westdale Ny
      Thanks. I’m usually tightening them up hand tight then a little turn with wrench. The. If it leaks which it’s done only once tighten a little more. Rather it leak a little and tighten a bit more than stripped. I’ve read the posts
      79 XS11SF
        • 5062
        Regarding the drain bolt: Yes, they are easy to strip while tightening. My advice to prevent that is to do away with the metal washer and use a nylon washer (14 mm?) They are durable and can stand the heat. They don't stick like metal does. It seals well and you can let off a little on the torque.
        • andreashweiss
          • 951
          good morning, if needed have 10 oil filter bolts and oil filter alum cup, stock used stuff, lets get one in your parts pile for $23 shipped by us priority mail, private message if anybody wants one, thanx andreas
          • dbmb0416
            • Jun 2015
            • 128
            • Westdale Ny
            I’ll remember that. By the way what’s everyone’s schedule for changes? 3 months or 3k miles?
            79 XS11SF
              • 5062
              I live in a dry climate. I also run the bikes for well over 20 minutes at a time. I go by mileage. 3000 miles to 4000 miles is good for me.
              • sethhope
                • May 2016
                • 226
                • Springfield, MO
                I go every 2500-3000 miles and after every winter.
                1979 XS1100F "Roxy" (my first bike ) - '91 Suzuki GSX1100 Fairing, BMW bags, Cheap ABS Trunk, aftermarket cruiser seat, MAC 4-2 exhaust, Heavy Duty folding kickstart, XS11 Special signals and gauges, Blade Fuse Conversion, Dynacoil Greens w/ ballast bypass, SS brake lines
