Pilot screw o rings
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65 -
$16 and free shipping is cheaper than the $3 each from Suzuki. After tax and shipping they were $22.Greg
The crazy thing is I keep thinking I put them in inside something so they wouldn't blow away. I'll probably find them as soon as these others arrive.
Sucks getting old.
Last resort solution... I bought a package of 3mm washers at the hardware store. They have the correct ID but the OD is 1mm too large. I proceeded to grind them down to size with a dremel while holding and rotating it in a needle nose pliers. Didn't even take 5 minutes to do 3 of them. I had one original one to copy the size from. For me, it was a better solution than waiting for or trying to track down the correct ones and the bike was down the road shortly thereafter.2H7 (79) owned since '89
☮Comment
Want me to mail you some ?OK dammit! I finally found the o rings and put them in a small plastic bag with the tiny washers in my tool box at work until I had a chance to install them. Well, I got a chance today and..............THEY ARE ALL GONE NOW!
I had them stashed in the corner of a drawer but I've torn my box apart and they are nowhere to be found. GRRRRRRRRRRRR
Where can I get a set of those tiny little washers?"If A equals success, then the formula is: A = X + Y + Z. X is work. Y is play. Z is keep your mouth shut." - Albert Einstein
1980 LG
1981 LHComment
The complete set that I got was in the tiniest plastic bag that could easilt be stuffed into a wrench socket. Did you check to see if they slipped into the couch cushions???
I'm an auto tech Sid, I had them in my toolbox at work. I ripped through all 15 drawers and both side cabinets. Even pulled out the lower drawers to make sure they hadn't fallen into the cabinet.
I work in a 12 bay shop, 6 bays on the south and 6 bays on the north. All the bay doors are open most of the time for air but the wind whips through here pretty good sometimes. Pretty sure they blew out of the drawer and away.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Yes they may have been more expensive but they were available! Sometimes it is not how much you pay but the fact that they are available! Would you have paid the 22 bucks if all other options were 100 bucks?2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Couple of more parts bikes of which 2 more will live!Comment
Not sure what you're trying to say here but, to answer a silly question, yes I would have paid $22 if the ONLY other option was $100.
I guess that I was trying to say that it is good that they are still available whether it be 13, 22 or 100 bucks instead of being unobtanium.2-79 XS1100 SF
