Pilot screw o rings
    Pilot screw o rings
    Someone here told me where to get some of those little tiny o rings that go on the idle mixture screws for the late carbs a while back but I don't remember where. I thought I saved that source but can't find it now.
    Can y'all help me out?
  • FJ111200
    • Oct 2007
    • 317
    • Crewe, Cheshire, UK
    Len at xj4ever.com http://www.xj4ever.com/
      Harbor Freight, there are tiny ones included in a plastic bag in the kit that work fine.
      https://www.harborfreight.com/225-pi...ent-67677.html
        Thanks. I think that's where I got them before.
          I have that set Phil, none small enough.
            Sorry BA, you need the metric kit P/N 67609, it has the 3x1 mm o rings.
              I got the 397 piece and there was no plastic bag. I'll go look again and see if they have what you're talking about.
                They are in this metric kit with 225 pcs...
                https://www.harborfreight.com/225-pi...ent-67609.html
                  I got some from ebay. They came with washers too. This was purchased in 2017
                  1978-83 Yamaha carburetor O-RING REPAIR KIT xs1100 xj1100 special mikuni BS CV
                  ITEM PRICE:
                  US $15.99
                  ITEM ID:
                  291825737800
                  SELLER:
                  retro-motorcycles (77348)
                  99.7% positive feedback
                    Thanks Phil. I went and got that assortment you suggested and it looks like those smallest ones will work fine.
                      Good, glad they worked for you, I knew they would. I just used some a few weeks ago.
                        • 3193
                        They are a suzuki number and are readily available last time I checked. Washers, Orings etc.
                          OK dammit! I finally found the o rings and put them in a small plastic bag with the tiny washers in my tool box at work until I had a chance to install them. Well, I got a chance today and..............THEY ARE ALL GONE NOW!
                          I had them stashed in the corner of a drawer but I've torn my box apart and they are nowhere to be found. GRRRRRRRRRRRR
                          Where can I get a set of those tiny little washers?
                            • 3193
                            I no longer have the Suzuki part number for the washers but I did post it somewhere on here a few yrs back. They are discontinued from Yamaha but Suzi dealers were still carrying them. Another possibility would be an electronics repair plce as they use a lot of smaller parts.
                              • 3193
                              http://www.xs11.com/forum/showthread.php?t=30756 will give you the suzuki part numbers
