Pilot screw o rings
    • 9981
    Pilot screw o rings
    Someone here told me where to get some of those little tiny o rings that go on the idle mixture screws for the late carbs a while back but I don't remember where. I thought I saved that source but can't find it now.
    Can y'all help me out?
  • FJ111200
    • Oct 2007
    • 317
    • Crewe, Cheshire, UK
    Len at xj4ever.com http://www.xj4ever.com/
      • 8963
      Harbor Freight, there are tiny ones included in a plastic bag in the kit that work fine.
      https://www.harborfreight.com/225-pi...ent-67677.html
        • 9981
        Thanks. I think that's where I got them before.
          • 9981
          I have that set Phil, none small enough.
            • 8963
            Sorry BA, you need the metric kit P/N 67609, it has the 3x1 mm o rings.
              • 9981
              I got the 397 piece and there was no plastic bag. I'll go look again and see if they have what you're talking about.
                • 8963
                They are in this metric kit with 225 pcs...
                https://www.harborfreight.com/225-pi...ent-67609.html
                  • 5073
                  I got some from ebay. They came with washers too. This was purchased in 2017
                  1978-83 Yamaha carburetor O-RING REPAIR KIT xs1100 xj1100 special mikuni BS CV
                  ITEM PRICE:
                  US $15.99
                  ITEM ID:
                  291825737800
                  SELLER:
                  retro-motorcycles (77348)
                  99.7% positive feedback
                    • 9981
                    Thanks Phil. I went and got that assortment you suggested and it looks like those smallest ones will work fine.
                      • 8963
                      Good, glad they worked for you, I knew they would. I just used some a few weeks ago.
                      • Rasputin
                        • 3193
                        • Lacombe, Alberta, Canada
                        They are a suzuki number and are readily available last time I checked. Washers, Orings etc.
                        2-79 XS1100 SF
                        2-78 XS1100 E Best bike Ever
                          • 9981
                          OK dammit! I finally found the o rings and put them in a small plastic bag with the tiny washers in my tool box at work until I had a chance to install them. Well, I got a chance today and..............THEY ARE ALL GONE NOW!
                          I had them stashed in the corner of a drawer but I've torn my box apart and they are nowhere to be found. GRRRRRRRRRRRR
                          Where can I get a set of those tiny little washers?
                          • Rasputin
                            • 3193
                            I no longer have the Suzuki part number for the washers but I did post it somewhere on here a few yrs back. They are discontinued from Yamaha but Suzi dealers were still carrying them. Another possibility would be an electronics repair plce as they use a lot of smaller parts.
                            2-79 XS1100 SF
                            • Rasputin
                              • 3193
                              http://www.xs11.com/forum/showthread.php?t=30756 will give you the suzuki part numbers
                              2-79 XS1100 SF
