running on 1 and 4
  • earl G
    • Aug 2007
    • 468
    • allentown,pa
    running on 1 and 4
    bike only is running on cylinder 1 and 4. change plugs, same, got a set of coils from running bike still the same. whats next?
    80 xs1100G
    • 5073
    Pick-up coil wire to 2 and 3.
      • 5073
      PS by now you have probably fuel-fouled the plugs for the non-firing cylinders.
      • earl G
        • Aug 2007
        • 468
        • allentown,pa
        ok start there. yes new plugs.
        80 xs1100G
          • 9981
          Pick up coils and/or wires to them Earl.
          • earl G
            • Aug 2007
            • 468
            • allentown,pa
            ok with wires to 2-3
            and how to test pick ups
            I also looked behind fuse panel a little dirt some connectors
            one was melted- had 4 wires in, 3 were white, 3 coming out those wires look as if they go to the gen.
            so that is were I am at
            80 xs1100G
              • 7831
              Pickup coil wires: http://www.xs11.com/forum/showthread.php?t=543
              The connector behind the fuse block: http://www.oregonmotorcycleparts.com/connectors.html Check with Tony to see if he has the connectors in stock. If not, you can find them at some auto parts stores or electronics shops. I would cut the old connector off at the wire, and crimp new on for that part. It does carry a LOT of amps, and ANY resistance ups the temp, and resistance in the connector.
                • 9981
                Alternator wires. Put new connectors on and it will solve the melting issue. Those old corroded connectors create a lot of resistance there and resistance causes heat. Some people have actually eliminated the spade connectors and just butt connected the wires there.
                • earl G
                  • Aug 2007
                  • 468
                  • allentown,pa
                  tony is out of stock..Yamaha dealer had them locked up in service dept. witch was closed.
                  I want to fix wire problem first.
                  to get bike to start
                  thanks for help
                  waiting for parts
                  80 xs1100G
                    • 9981
                    The metal connectors on both ends too Earl.
                      • 9981
                      Get your bike figured out Earl?
                      • earl G
                        • Aug 2007
                        • 468
                        • allentown,pa
                        got new plastic and metal connectors.
                        cleaned all wire connectors behind fuse box and next to.
                        took out battery to check water level.
                        need to put battery in and turn the key and watch what happens.
                        80 xs1100G
                        • earl G
                          • Aug 2007
                          • 468
                          • allentown,pa
                          still no fire on 2/3
                          back to the coil pick wires ,better look
                          how this started: was going for a ride one day, started bike to warm up was running fine. shut off to get coat and helmet went back out got on bike to ride and stared it lost 2/3. ??
                          80 xs1100G
                            Hey Earl,
                            Aside from the PU coil wires, another place to look is a the TCI and it's plugs. Corrosion can build up there also. And inside the TCI. The solder joints from the external plugs to the circuit board...can also corrode or go bad. Some folks have had to RESWEAT the solder joints inside the TCI case to get it to work right again.
                            To check spark on a coil, you need to leave one plug wire attached to the plug in the engine, lay the other with a plug in the wire against the engine/head so that it can ground against the head to complete the circuit between the 2 plugs that the coil services. Then you can turn the engine with the starter button and check for spark If you see spark on 1-4 but not 2-3, then you can swap the COIL wires/plugs, the gray and orange to the other harness plug/ swap them. Then retest. IF then the spark is on 2-3 and not 1-4, then you know the coils are OK. If after the swap, the now swapped 1-4 fire, but not the 2-3 coil, then the TCI /pickup coils are working, but you've found a bad ignition spark plug coil.
                            I know you said you got one from a working bike, but if these are OEM coils, they are 35+ years old and on their last legs, and would highly suggest putting on NEW Hi output coils to finally eliminate that as a source of problems. Remember, with the 80, you'll need to bypass the Ballast Resistor with a new set of 3.0 ohm coils.
                            • earl G
                              • Aug 2007
                              • 468
                              • allentown,pa
                              So today got new spark plugs checked gap. Did test and have spark on
                              2/3 with switching wires. And spark on 1/4 when switch back
                              Next test please
                              80 xs1100G
