Squealing brakes
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    Squealing brakes
    Been using EBC FA34 organic pads forever with no issues. Replaced pads, both ends on last tire change. Have couple hundred miles on them and both ends have started to squeal. Real annoying. Pulled fronts. Looked ok. Cleaned up with grinder, very light resurfaceing. Cleaned ALL mounting surfaces. Emery cloth cleaned all sufaces of fairly smooth rotors. Quick run around block and all seemed good. Rode to work and squealing is back. Brake action is very good except for the annoying squeal. No pulsation in brakes.
    • 5062
    Do you have those thin metal "shims"? Are they supposed to help prevent squeal?
    • webbcraft2150
      • Sep 2002
      • 1605
      • AUSTIN.TX
      Shins are not there😱. I left them out on the last brake job. Had it all reassembled on found em sitting on the bench. Blew it off. Of course now I can’t find them 😤
      • MPittma100
        • Aug 2011
        • 2359
        Brake Squeal
        Pull the calipers off again. Go to the auto parts store and buy some anti-squeal compound liquid. Apply to back side of pads and your problem is solved. It is red in color. Just did it to my front brakes. No more noise.
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          • 8796
          You can also file the leading edge of the pad(s) with a 45* angle, works for me with the cheaper pads I usually use.
