Syncing Carbs
  • CivilPenny
    • Sep 2017
    • 26
    • MI
    Syncing Carbs
    Can someone explain the Proper hose hook up system so sync my carbs? I have had a friend do it before but tuned mine and need to re sync.
    I have read the main directions from the carb sync page, but get mixed up in one spot and want to make sure I get it right.
    "Remove the vacuum line from the #2 carb on the manifold side of the carb, this is the one from the vacuum control splitter, not the vacuum advance line."
    I get confused here..Vacuum control splitter??
    Remove the rubber caps from #1, #3, and #4 carbs.
    Connect the mercury sync tool to carb #1-#4 where the caps/vacuum hose was disconnected"
    My carb boots ALL have caps on them, not just 1,3,4. The vacuum advance line runs to a brass pole on carb #2. Before, I would remove that line and hook up the sync hoses to the 4 spots where I removed the rubber caps, then proceed to sync the carbs. Am I doing this properly? Should the vacuum hose remain in place? Should sync hose be placed on the brass pole I mentioned instead of on the rubber boot like the rest?
    If someone has pictures, feel free to attach them. Thanks!
    79 SF Special
    80 Special
    • 2162
    It's really simple.
    Leave the vacuum advance hose in place. Remove the hose that opens the gas supply (octy or petcock).
    Remove the three rubber caps on #1, #3, and #4.
    Attach the sync tool to the four exposed brass fittings.
    • CivilPenny
      • Sep 2017
      • 26
      • MI
      Now that confused me more...hose that opens gas supply?
      My fuel petcocks (left and tight) each have 2 nipples. One nipple (on each petcock) goes to the carb gas t’s, and the other line joins the nipples together
      79 SF Special
      80 Special
        Civil - your fuel system has been modified. Attach the four sync tool hoses to the four vacuum nipples in a row on top of the intake boots. The fifth nipple, the one that comes off of the body of carb #2, stays connected to the vacuum advance.
        • CivilPenny
          • Sep 2017
          • 26
          • MI
          Awesome, Thank you!
          I figured it couldn't have been too complicated...
          79 SF Special
          80 Special
