Help I broke a bolt.
    • 8670
    Look at the pipe too, may have a crack in it near the bolt.
    • speedlimit85
      • Jan 2017
      • 423
      • Gainesville, Fl.
      Okay. I will. Thank you.
      80 G
      • speedlimit85
        • Jan 2017
        • 423
        • Gainesville, Fl.
        The threads are stripped. I'm having a bad day. I feel like I destroyed the motor.
        80 G
          • 7640
          You can buy a tool to insert the thread. As it's an oil line, you will need to be sure all chips come out before installing the thread insert.
          Take the banjo bolt down to a good parts store and they should be able to help you.
          • speedlimit85
            • Jan 2017
            • 423
            • Gainesville, Fl.
            It went in cross threaded last time. I wish I had listened to Phil and loosened the top bolt It was hard to start. I think that is why oil was seeping out. I will try CRL Loctite Form-A-Thread 28654 maybe it will work.
            80 G
              Fix it properly or you will be doing it over (IMHO)
              Keeping the oil in the engine is essential to it`s continued existence
              • speedlimit85
                • Jan 2017
                • 423
                • Gainesville, Fl.
                Yes. It has to be done right. I regret cross threading, but it would become much worse running the motor without oil.
                I will get help from a mechanic.
                80 G
                  • 8670
                  Eric, if I were closer I would be able to help you. Here is how I would go about fixing this. First, I would remove the tank and carbs so there is plenty of room to work. Find out the size and thread pitch of the banjo bolt and get a threaded insert kit such as a Helicoil or Tapsert. Cut off a small piece of rag and jam down the hole to be repaired as to catch any metal shavings created by the thread tap. Go ahead and tap the hole to the correct depth and then take a wet vac and suck out the metal shavings. Pick out the rag and install the insert following the directions with the kit. Use 2 new copper washers on the banjo bolt and install the line. If done properly you should be good to go. Good luck with your repair.
                  • speedlimit85
                    • Jan 2017
                    • 423
                    • Gainesville, Fl.
                    Thank you Phil. I think this repair is beyond me at this time. A local shop is very good. I will ask him tomorrow, and hopefully trailer the bike there in the afternoon.
                    80 G
                      • 8670
                      Yep, I hear you bro, let us know how it goes.
                      • speedlimit85
                        • Jan 2017
                        • 423
                        • Gainesville, Fl.
                        Bike is fixed!
                        80 G
                          • 8670
                          Thats great news! Did it give the mechanic a hard time, removing the carbs and all?
                            • 1545
                            Bike is fixed!
                            Fantastic ............
                            Now you can ride again. We sure enjoyed riding with you in March at XS FLA Rally. Your bike ran great.
                            • speedlimit85
                              • Jan 2017
                              • 423
                              • Gainesville, Fl.
                              I am lucky there is a good shop in town.
                              80 G
                              • speedlimit85
                                • Jan 2017
                                • 423
                                • Gainesville, Fl.
                                Yea. I like the bike. That was a great ride, we've gotta do that again.
                                80 G
