brake light connection
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    It's been a while since doing any work on the SG.
    so,
    here's a dumb question. How does that brake light connection disconnect from the m/c.
    I removed the ring and it's basically not pulling off. Thought I'd ask before I pull any harder and mess it up.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    Front Master Cylinder
    On the bottom of the MC under where the switch goes in there is a small hole. Take a mini screwdriver and push it in that hole while pulling out the switch. This will push in the tab holding the switch in.
    • DeanR
      • Jan 2005
      • 1499
      • Finger Lakes NY
      Thanks Phil. That was easy.
      No recollection of that hole. Perhaps I've never had to do that.
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
        No problem Dean.
        • DeanR
          • Jan 2005
          • 1499
          • Finger Lakes NY
          Question 2 has arisen. How the heck does one remove the little dust boot of the m/c to get to the snap ring without ripping it to shreads?
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
            Not much you can do to avoid tearing the aged rubber. May want to try pouring some brake fluid around the part that is stuck and see if that breaks down the corrosion. The M/C will still operate without that boot if it does tear. You may want to buy a M/C rebuild kit with new parts if you find the rest of the piston/snap ring are corroded.
            • DeanR
              • Jan 2005
              • 1499
              • Finger Lakes NY
              How/where is that boot secured Phil? so as to yank on it correctly. Can't find a picture or diagram anywhere.
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
                IIRC, there is an internal metal band at the base that is forced into the M/C. May try prying at the base. I think every one I tried to remove had ripped, GL.
