Special Fork Bushings
    Has any of you ever replaced, or had replaced, the fork bushings. Who does it? How much does it cost? It appears dirty oil tears them up.
    The lower bushings, the ones on the stanchions can be easily replaced, the upper ones in the legs are pressed in and are a real bear to remove and not easy to find. I got some a long time ago from Jim Lindemann in California and I had to size them myself, what a pain. Probably a better option to get a low mile pair of forks and polish them up to look as nice as yours.
    Edit: here is the link...
    • MPittma100
      • Aug 2011
      • 2359
      Fork bushings
      I believe Traxxion Dynamics has them and can install.
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
        Thanks Mike. I should have thought of that.
        As it turns out, XS1100SG is in their data base. I'm currently running their springs.
        • MPittma100
          • Aug 2011
          • 2359
          Fork bushings
          From memory, the SF forks they did for me, I'm pretty sure that they had and replaced the bushings as part of the upgrade.
          K&N Air Filter
          ACCT
          EBC Front Rotors
          Mike
