Pet cock question.....
  • brcree
    • Mar 2010
    • 388
    • S.C.
    I have a 81 Special and have just read the tech tip on inline filters. In the pics related to this article, it looks as if only one fuel hose is going to each pet cock. So....what outlet do you hook the fuel hose up to? There are two.
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
    The forward port goes to the tee, bypassing the vacuum shutoff.
    Is your vacuum shutoff missing. Some folks delete the safety device. I'll defer to them if you're doing that.
    • brcree
      • Mar 2010
      • 388
      • S.C.
      Pet cock
      The vacuum system was missing when I got this bike. So I should use the front port with out a vac. unit?
      At this time:
      1985 Goldwing Innr.
      2007 vtx 1300
      81 sx 1100 s h
      81 sx 400 special
        No. Both ports are going to run fuel. You have to cap one of them or acquire a vacuum shutoff and plump it as in the diagram I posted. I'm sure someone will give you a vacuum shutoff (spidervalve or octopus) for free or close to it.
        The vacuum shutoff is supposed to shut fuel off in case of accident. The tip over switch kills the ignition and subsequently, the vacuum switch cuts the fuel.
        • brcree
          • Mar 2010
          • 388
          • S.C.
          Pet cock
          Ok, my question still is.....by not using the vac. system, witch port do I run so as to cap off the other?
          At this time:
          1985 Goldwing Innr.
          2007 vtx 1300
          81 sx 1100 s h
          81 sx 400 special
            Pick one. One is PRIME. The other is ON. I don't remember which one flows for RESERVE.
            • brcree
              • Mar 2010
              • 388
              • S.C.
              Pet cock
              Thanks for your input. Guess it doesn't matter. I've looked at some diagrams of how to rout the fuel hoses. Its not rocket science is it......lol, thanks again.
              At this time:
              1985 Goldwing Innr.
              2007 vtx 1300
              81 sx 1100 s h
              81 sx 400 special
                The front is prime, use the rear on/off outlet for the filter.
                • brcree
                  • Mar 2010
                  • 388
                  • S.C.
                  Pet Cock
                  Thanks BikerPhil.......
                  At this time:
                  1985 Goldwing Innr.
                  2007 vtx 1300
                  81 sx 1100 s h
                  81 sx 400 special
