Right rear wheel bearing
    • 8061
    Any of you got a spec or part number for the right rear wheel bearing? I'd like both rear grease seals, too. Any of you stashed some numbers?
    Thanks
    • 1580
    I used the Yamaha Bearing Part # 93306-30437-00
    Yamaha Seal was Part # 93104-27026-00
    Will pull my Invoice to confirm (if i can find it)
      • 8892
      I found this I posted a while back...
      Right Rear Wheel Bearing - 6304 2RS 20X52X15 (Yam. # 93306-30404-06)
        • 8061
        Thanks guys! OEM from Partzilla is over $30 for a bearing. A Koyo ball bearing from another source is about $5.
        Phil, do you have specs on the rear seals in your info stash?
          • 8892
          I know the left side seal is 25 38 6, I'll post the size of the right side when I find it.
            • 8892
            Right side seal is 27 52 5
              • 8061
              Thank you!
                • 8892
                You're welcome Marty.
                  • 8061
                  Got front wheel bearing dimensions?
                    • 8061
                    Got it. 17x47x14
                      • 8892
                      Got it. 17x47x14
                      Hope you didn't have to take the wheel off the bike to find the correct size like I did. JK
