Right rear wheel bearing
    Any of you got a spec or part number for the right rear wheel bearing? I'd like both rear grease seals, too. Any of you stashed some numbers?
    Thanks
    • 1591
    I used the Yamaha Bearing Part # 93306-30437-00
    Yamaha Seal was Part # 93104-27026-00
    Will pull my Invoice to confirm (if i can find it)
      I found this I posted a while back...
      Right Rear Wheel Bearing - 6304 2RS 20X52X15 (Yam. # 93306-30404-06)
        Thanks guys! OEM from Partzilla is over $30 for a bearing. A Koyo ball bearing from another source is about $5.
        Phil, do you have specs on the rear seals in your info stash?
          I know the left side seal is 25 38 6, I'll post the size of the right side when I find it.
            Right side seal is 27 52 5
              Thank you!
                You're welcome Marty.
                  Got front wheel bearing dimensions?
                    Got it. 17x47x14
                      Got it. 17x47x14
                      Hope you didn't have to take the wheel off the bike to find the correct size like I did. JK
