1982 XJ1100 Rebuild
  • gene
    • Mar 2009
    • 267
    • Weston, Fla.
    So I'm going to keep the XJ1100 triple tree and fork setup. I bought bar clamps that look really nice. I assemble the bars on my bench. I used FZ09 components. Now I need to change all the plugs to match the XJ. The levers are adjustable and super smooth. I'm tempted to change my XS1100 as well. Pulling those old levers is not very smooth.
    I know what to do on brakes now.
    I am going to lower the light and gauges, but I do need to change out the gauges. The current setup is not the look I'm looking for and it's in ok shape.
    Gene (Florida)
    1980 XS1100SG
    Accel Coils
    4-1 Jardine Exhaust
    • gene
      • Mar 2009
      • 267
      • Weston, Fla.
      Originally posted by FJ111200
      I de-linked the brakes on my 81 Midnight Special, it's the same set up and parts that are on the XJ, but I found that the rear brake became weak due to the way that the actuating valve in the m/c works on both brakes and so swapped that over to an XS1100 Standard rear m/c which seemed to improve things.
      So then on the front brakes I used a m/c from an FJ and used braided steel lines which also helped the situation. Don't forget to use a brake line splitter from another model for the front set up in whichever method you go for.
      Since all this I've now got an XJR1200 complete front end set up on my Midnight.
      I wish I could get the XJR1200 parts. We can't get them here. I might try to grab some stuff when I visit the UK and Germany first week of April.
      Gene (Florida)
      1980 XS1100SG
      Accel Coils
      4-1 Jardine Exhaust
      • XJkid
        • Jun 2003
        • 280
        • Elk Grove, Ca.
        Originally posted by soccer4m
        a lot safer as the xj tends to go straight on braking in a curve. Mike in Sun DIego
        I'm hip!! I just about lost it on a curved onramp in Sacramento this morning. I misjudged my approach angle and braked, but the bike did not want to turn. I had to put my foot down in case I dropped it.
        • soccer4m
          • 694
          Been there XJ Kid
          Glad you survived the turn Xj kid,,,,also happened more than a few times with me. From what I read through the threads the easiest way to solve the linked system is to get an XS1100 rear cylinder and plug the line at the front junction box. Using the xj rear involves some rearranging of the lines and pressure valve and also plugging the front. THe lines are so short from the rear to the brake the regular rubber is ok, but S Steel braided is bullet proof and stronger. WIth the ss line of my XS1100 the rear is very strong. SO,,,,the xj is next on the project list to ditch the linked system. Ride on,,,,,,Mike in SUn DIego
          mike
          1982 xj1100 maxim
          1981 venture bagger
          1999 Kawi Nomad 1500 greenie
          1959 wife
          • gene
            • Mar 2009
            • 267
            • Weston, Fla.
            Thanks for the feedback. The concept just didn't jive. I also noticed uneven wear on the front pads when I took them apart. The old owner had the one set of pads almost gone and the other side looked like new.
            Gene (Florida)
            1980 XS1100SG
            Accel Coils
            4-1 Jardine Exhaust
