Can the actual wires on pickup coils be COMPLETELY replaced somehow??
  • speedlimit85
    • Jan 2017
    • 493
    • Gainesville, Fl.
    Originally posted by skids
    I know this sounds kind of stupid, but on one of mine, I put long enough wires to make loops. This keeps the "kinked angle" at a minimum and the repair has lasted many years. If you do that, make sure there is no rubbing.
    Cool idea. I just did that.
    80 G
    • speedlimit85
      • Jan 2017
      • 493
      • Gainesville, Fl.
      I put the longer wires too loose. Today the timing plate shredded 3 wires. I re-did it with new wire, butt- connectors,and wire ties hopefully holding the wires away from the timing plate.
      If I have to, I'll keep trying til it lasts...
      80 G
      • speedlimit85
        • Jan 2017
        • 493
        • Gainesville, Fl.
        I read this more carefully. The connectors I used are long and have heat shrink attached. It is working now, but shorter butt-connectors then heat shrink with longer wires that are carefully placed and held in position so they can move with less tugging seems ideal.
        I may not have enough original wire from the pick-up coils to do another repair, but it could last years... I hope.
        Thank you guys. I have been continuing to learn how to trouble-shoot, repair, and improvise.
        80 G
