81' Special re-hab
  • SNDSLGR
    replied
    2 of 3 bolts snapped on each header when I removed the heat shields. I used a dremel cutoff wheel to cut what I could of the weld and then a chisel and hammer to remove old threaded bung so I could weld new nuts into place.
    Leave a comment:
  • SNDSLGR
    replied
    Put the headers back on bike and figure out mounting etc for mufflers. For the Supertrapp mufflers I chose (443-1717) I need a 5" extension to make it work.
    The inner tube is 1-5/8" OD. A piece of 1-3/4" exhaust pipe is a near perfect fit to slide over the stub. Weld it up and grind it down smooth.
    Mock up shot. I cannot weld SS so will have to get the bike over to my buddies house. I plan to make a SS mount tab like the stocker and get ride of the strap at a later date.
    Leave a comment:
  • SNDSLGR
    replied
    Cut the mufflers just rear of the dimple about 4" behind the smallest part of cone.
    Next if you look close there is a slight bulge 1/2" behind the weld. I marked it with a sharpie to use as a guide once I break thru first tube. The exhaust is double walled here, the inner tube reduces and the outer tube expands at this point.
    Use a cutoff wheel and carefully cut off the outer ring only, leave the inner tube in tact to sleeve over later.
    Leave a comment:
    replied
    Yep . . .
    Pics are comin' through now, looks good, got more ?
    Leave a comment:
  • SNDSLGR
    replied
    This seems to work?? (thanks for the incog idea)
    Leave a comment:
  • dansmith65
    replied
    FYI: A good way to see the same thing others are seeing is to use an "Incognito Window", or "Private Browsing" (different browsers use different terminology). I often use that to test public links before sending them to someone. The reason you can see the images is because your logged into your google account in your browser. If you open an "Incognito Window", then that window won't be logged into your google account, so you can see what we're seeing.
    Leave a comment:
    replied
    Originally posted by SNDSLGR
    anyone else? can you see my pics on this thread?
    Not a one
    Leave a comment:
  • SNDSLGR
    replied
    Leave a comment:
  • spectra
    replied
    Are all those pics not showing up? I put up about ten yesterday
    Nope just little black boxes with an x in it.
    Pics stink now that photobucket took a crap.
    Leave a comment:
  • SNDSLGR
    replied
    Leave a comment:
  • spectra
    replied
    No pics?
    We need pics
    Leave a comment:
  • SNDSLGR
    replied
    Leave a comment:
  • SNDSLGR
    replied
    Clean it up and prep for mock up and welding.
    The inner tube is 1-5/8" OD. A piece of 1-3/4" exhaust pipe is a near perfect fit to slide over the stub left being. Weld it up and grind it down smooth.
    Leave a comment:
  • SNDSLGR
    replied
    s
    Leave a comment:
  • SNDSLGR
    replied
    Been a while. I got it running close to right, I'll wait to do a final tune until I get the exhaust back from ceramic coating.
    Headers where nice and strong metal through out but the mufflers where getting soft. I've read enough about good headers being hard to find and wanted to preserve mine so I decided to cut the mufflers off and rework them for aftermarket mufflers.
    Some of this has been covered by others but here is a step by step for anyone considering the same.
    (I'll have to pick this back up when I get home... Having a hard time posting pics from phone.
    Leave a comment:
