81' Special re-hab
Cleaned and re-finished the rotors and lower fork legs then got the new tire mounted up and installed new brake lines and MC. Its starting to look pretty nice.
Took the front end down and cleaned some of the chrome up. Soaked it in the same phosphoric solution I used on the tank.
Leave a comment:
Thanks and have used them before for fuel lines for my diesel. Thought maybe there was another game in town.....
I was just actually next door to them last week and should have went in but didn't even think about it.....Leave a comment:
It's called "oil filter service shop" downtown Portland on market Street. Great place, makes your parts while you wait.Leave a comment:
Only 1 day off to work in garage but got a lot done today. Took it for a ride this morning and checked coils while hot, no trouble found. I pulled the carb bank and adjusted the float height then put in 47.5 pilots. Im fairly sure my main is 1 lean and im compensating it with too big of pilot but at least its running smooth now.
Took the wheels off and got them cleaned up then had the old rotten tires removed. Ill refinsh the wheels next week.
Also ran up to a local hose shop and had some custom brake lines made I can install when new tires and refinished wheels go back on.Leave a comment:
Since your scoot has the drain-screw seats on sides of float bowls, slide a piece of see-thru fuel line on nipple on bottom of fuel bowl. Start bike, and at idle unscrew the seat screw while holding fuel line up beside fuel bowl. Fuel in that line will be the actual fuel level in fuel bowl. That actual level with bike idling is 3mm down from carb body casting where fuel bowl attaches. All four carbs need to measure the SAME 3mm. So, with that, just lowering float bowls the 1mm as per your statement IS incorrect. FWIW, 1mm of actual float change equals 3mm of fuel level change. If your insistant on just changing float level settings, I suggest not changing them more than a 1/2mm at the most. The actual fuel level setting procedure as previously stated IS also the required method for 81-82 XS and XJ's, as stated in the original Yamaha shop manual. Having this advantage with these later model carbs makes for getting float levels set so that all four carbs fuel levels are the SAME. Also, this procedure, with several carb bank removals and installations makes one cut that removal time down to approx. 12min., starting with seat and tankAgree about the jetting.. its strange, it feels and sounds too rich but backing out the screws improves the problem, but never goes away once warm. Im very familiar with Keihn slide carbs w/fixed float, not much time with these Mikuni CV carbs.
Plan of action is 1) go over electrical real good and 2) lower fuel level 1mm. This quote from factorypro.com is exactly what im experiencing.
"a bike that runs cleanly at small throttle openings when cold, but starts to show signs of richness as it heats up to full operating temperature, will usually be leaned out enough to be correct if the fuel level is LOWERED 1mm. / FUEL LEVEL IS EXTREMELY IMPORTANT!!!"
Weather here is terrible and my work cycle starts tomorrow night so Ill have the new tires I ordered by the time I have any time to really get into it.
Thanks all.
Leave a comment:
Agree about the jetting.. its strange, it feels and sounds too rich but backing out the screws improves the problem, but never goes away once warm. Im very familiar with Keihn slide carbs w/fixed float, not much time with these Mikuni CV carbs.Hey there,
The 81 had 42.5 stock pilot and 110 mains, so you've gone up 1 size pilot and 3 sizes mains already, don't think you need to go up another pilot size? Your description of "BOGGING/Surging" almost sounds like too rich to begin with and it only picking up once the rpms get high enough to catch enough air to handle the excess fuel!!?
It's still possible that your carbs are having ignition problems.
Thanks all.Leave a comment:
Hey there,
Like Skids said, you can run the bike until it starts acting up and then stop it and recheck the secondary resistance. The primary resistance is a bit harder to check on the side of the road, especially having to take the tank off and such to get to the harness connectors. It's possible the windings/coils could develop a short or break when they heat up. Also as stated, they are 35+ y/o wires and could be shorting thru the insulation to the frame also.
The Accel # you have is correct, and the DYNATEK # is the DC1-1 3 ohm style. Both are the 3 ohm type for older ignitions, you do NOT want any type for CDI type ignitions.
The 81's are a lot less prone to the pickup coil problem than the earlier models due to only the vac. adv. causing the wires to flex, no mech cent. adv. rotating the plate, it's programmed into the TCI, but you can still check them to rule them out.
T.C.Leave a comment:
Have you checked for broken P/U coil wires under the left side ignition cover?Leave a comment:
I know that bad coils can show drastically increased ohms when hot. plug caps can go bed as well. It is relatively easy to test plugs and caps at the same time...just pull them off the plugs and test Kohms on the pairs. It won't tell you if the problem is with the cap(s) or the coil, but it will indicate if there is a problem. What it might not indicate is if you had voltage escaping out of a spark wire, moving it for the test might show it to be good. You might be able to see arcing in the dark if the wire is bad.Leave a comment:
Could use a little help fellas.
*some current specs real quick.
Stock coils
Stock exhaust
mikesxs oval pod filters
stock needle
stock air jet
pilot 45
main 117.5
fuel screw out 4 turns
Coils
1/4 primary 2.4 (spec 2.5)
2/3 primary 2.5
1/4 secondary 11.15 (spec 11)
2/3 secondary 11.22
Plug caps
1, 9.79, ordered new
2, 5.72, replaced with new 5 ohm
3, 5.53, replaced with new 5 ohm
4, 8.79, ordered new
*Bike starts and idles great, I have done a carb sync (even hooked it up once after I started having trouble to be sure... all good)
The other day when I first started the bike it ran decent but bogging/surging pretty bad at 3 turns and got worse as it warmed up, came out to 3.5 and still doing it but slightly better.
Next morning I took the coils out and checked them, all within spec. Replaced the two inner plug caps and fired it up. Much better but still not quite right so I turned the fuel screws out to 4 and it ran great.
This morning I warmed it up then rode to the store about 3 miles. I was so happy, thought I had it nailed!! Riding back from store it started acting up on the low end again. Got home and moved the fuel screw out another half turn with no effect. (not surprised.. dont know the exact number of turns before its dead open but gotta be close at 4.5?)
Im going to try 1 size up on the pilot jet.
So to my question...
1) Im feeling like my coil/wires may have a crack and reading well at room temp but giving me trouble when they get hot, sound reasonable?
2) Ive read much as I can on here but having trouble being sure which Accel coil kit to get... much of the posts here are very old (is info still relevant to todays market/availability) and almost all of them deal with the earlier models. This is a 81' with different specs than most. Book says 2.5 ohm primary and 11 ohm secondary. From what I can gather Accel is the way to go? And the Accel #140403 is the right coils, anyone have input on that?
Plugs are reading a tad lean, not bad but a tad. I cannot do anything with the top end yet (although I feel its close as it pulls very hard to 50 mph), the 25 year old tires and spongy breaks need to be addressed before any high speed passes.
Thanks for reading.Last edited by SNDSLGR; 11-04-2017, 02:26 PM.Leave a comment:
It fired right up! Ran around the neighborhood a bit to get thru the gears and get a feel for the jetting. Low end needs a little work.
New tires and brakes lines before I really lay into it... They are in pretty bad shape.Leave a comment:
Leave a comment:
