Carbs where unreal.
Looking good now
. Oherwise, the one on outer two cyl. is easiest access. One on rear two cyl. is a pain since the whole air filter assembly has to be removed in order to access that self-adjuster
. Also, and likely very important is keep the retainer bolts with the Venture self- adjuster. The housing mount locations are a bit taller, and the bit taller mount locations require the longer Venture mount bolts.
Leave a comment:
