Horns
  • leggman1
    • Oct 2016
    • 130
    • Winchester, KY
    81 XS11
      • 7831
      Try and tilt the horn so the opening is pointed down a little more. It will still be loud, but it will keep the water from entering and killing the horn.
        • 9981
        Originally posted by diverray
        try and tilt the horn so the opening is pointed down a little more. It will still be loud, but it will keep the water from entering and killing the horn.
        +1
        • HalfCentury
          • 408
          • Burlington NC
          Originally posted by red bandit
          What gauge is that new fat wire?
          10 Gauge. Its what I had on hand. It might work just fine with thinner gauge.
          82 XJ1100 - sold
          96 Honda Magna 750 - Girlfriend's bike
          2000 ZRX1100 - sold
          2003 FJR1300 - Silver rocket
            • 9981
            When I did mine I used some of that heavy speaker wire the millennial crowd uses for the BOOM BOOM stereo in their cars. Not sure what the guage was but it's much more flexible and easier to route than regular electrical wire.
            • MPittma100
              • Aug 2011
              • 2359
              Direct Battery Ground
              If you really want to get the best results for horns or any other accessory, improve all of the chassis grounds to direct battery grounds. Chassis grounds are only barely good enough to burn a light bulb.
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
                • 9981
                Did that long ago Mike. The factory frame grounds are horrible.
