Odometer not working.
  • Crusty Snippets
    • Sep 2010
    • 428
    • Gabriola BC
    79 XS11 Special. Speedo quit. Cable had snapped. Replaced cable and drive unit . Speedo works, but the odometer does not. Any suggestions before I look inside.
    Thank you. Crusty
  • leggman1
    • Oct 2016
    • 130
    • Winchester, KY
    You have probably already tried this but turning the tripmeter reset knob might help?
    81 XS11
    • Crusty Snippets
      • Sep 2010
      • 428
      • Gabriola BC
      Yes, reset to 0000. OD reads 16km after 2 months of riding. So it does slowly turn.
      CS
        • 9980
        Just get another speedometer. I have a big box full of speedometers I've TRIED to fix.
        There's a nylon gear in there that has worn out.
          Worn Out after 30+ years. Gees i wonder if todays Nylon would last 10 years
          • HalfCentury
            • 408
            • Burlington NC
            You can obtain other vintage Yamaha speedo/tach assemblies. Many of them have common a speedo cable.
            I used a Speedo from an XS650 that had been wrecked and parted out. The odometer had 62 miles when I bought it.
            It worked sweet in the XJ1100.
            Surgery was required to bring out the trip odometer shaft and knob. The stock XJ1100 has a completely different scheme for resetting the trip odometer.
            I had to take everything out of the housing, replace the speedo, drill a hole in the side of the housing and install the new speedo.
            After re-assembly, you would never know it was not stock unless you were an XS/XJ junkie. Two clues are that the stock XJ speedo only goes to 80 mph while the XS650 speedo goes to 120 MPH (if I recall correctly). The other clue is the the modified speedo has a trip reset knob out the side while the stock XJ has a trip reset button on the face of the speedo housing.
            Compared to fixing a second gear slippage, a speedo transplant is a breeze.
            82 XJ1100 - sold
            2000 ZRX1100 - sold
            2003 FJR1300 - Silver rocket
