Broken stud on fork slider
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    Is it best to heat/wrench the stud out, or find a replacement slider?
  • Tenorman
    • Oct 2013
    • 70
    • Butler, Penn.
    That would be my first thought...
    My thoughts...
    You could...drain the fork oil first...
    In my opinion, I would probably try the mild heat first...heating around the stud...with a pair of vice grips on the stud...heat and maybe spray some PB Blaster while hot and repeat the process as many times as necessary...slow and steady wins this race...
    If that doesn't work, drain and remove the fork (you'll probably need some heat on those bolt, too)...
    Remember, slow and steady...take your time...no rush...
    Tenorman
    Bikes that I have owned and enjoyed...
    1964 Allstate 250
    1970 Yamaha DT1
    1959 Mobylette
    1970 Yamaha JT1
    1995 Suzuki 80
    1978 Yamaha XS650
    1980 Yamaha XS1100LG
    2005 BMW R1150R
      I broke one. I had the retaining cap backwards. The arrow points to the front, but mine had no arrow. Use heat and hit it with Kroil penetrating oil. As it cools, it draws the oil in. Got mine out using a pipe wrench with good sharp jaws.
        • 4015
        Just put a pair of vice grips on it. It'll spin right out!
          How about a stud puller?
            Originally posted by Tenorman
            My thoughts...
            Tenorman
            LoHO,
            As suggested above I would remove the fork and drain and then work it out, as suggested above, with gravity helping the penetrating oil get in the threads.
            When it snaps off flush you will have to remove the fork anyway
              Yes, you will get the "pucker" when you try turning it out! Have faith Larry!
              • MPittma100
                • Aug 2011
                • 2359
                Broken Stud
                Heat only the stud. Propane torch is plenty of heat. Let it cool a bit. Screw it out. Use anti-sieze on threads of new stud.
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
                • LoHo
                  • Sep 2002
                  • 1342
                  • Fresno, CA
                  Any ideas about a replacement stud? Or can I just improvise one by threading an existing bolt?
                    • 4015
                    Yes, goto Ace Hardware. They stock them.
