1981 xs1100 running rough at low rpm
    Hey Dave,
    Glad it's behaving better. As to pulling the plugs after a short run, you need to perform the throttle chop method to properly evaluate the MAIN JETS.
    Find a decent slight incline grade, hold the throttle steady at around 4-5k rpm for 30 seconds to a minute, then hit the kill switch while pulling in the clutch at the same time, coast to the roadside, and then pull the plugs and take a look.
    If you just ride it around a bit and then pull the plugs, you'll be checking the pilot jets mostly.
    And remember, the Pilot jet screws are FUEL/AIR mixture screws, not air screws. More turns out richens, turns in leans.
    • leggman1
      • Oct 2016
      • 130
      • Winchester, KY
      Have you ever used a colortune plug?
      81 XS11
        • 5062
        I have a colortune kit. That device is more for setting idle circuit richness. It won't tell you what is happening under load.
        • leggman1
          • Oct 2016
          • 130
          • Winchester, KY
          #34
          it is running somewhat better but still not right. I went for a short ride a little while ago and I think its only running on three cylinders. sometimes the forth one kicks in and it smoothes out and has way more power. I am suspecting a stuck needle in number four carb. When I first put it back together the needle in 4 was stuck open and gas was coming from everywhere
          I tapped on the bowl and the gas stopped. so now I think it is starved for fuel because #4 is sweating and the other three are dry.
          81 XS11
          • leggman1
            • Oct 2016
            • 130
            • Winchester, KY
            #35
            OK this time I really got it. The only thing I didn't do when I went into the carbs the other day was pull the floats and clean the needles/seats/screens. Today I did and I found a bunch of crapola under the #3 screen which was blocking fuel from getting into the bowl.
            After a good cleaning and some reassembly it starts great runs strong on ALL cylinders and idles smoothly at 1000 rpm. NO and I mean NO hesitation when you give it a twist. It will be tomorrow when I can go for a good ride but I really believe it is fixed Woo Hoo.
            Thanks to all who helped. Dave
            81 XS11
              • 8798
              Dave, are you running fuel filters? If not, it might be a good idea.
              07 Triumph Tiger 1050
              • leggman1
                • Oct 2016
                • 130
                • Winchester, KY
                #37
                Yes, I have two small filters (one for each side) coming off the tank. I eliminated the octy and plugged the front tubes on the petcocks.
                When I pulled the needles and seats I noticed the seats has small screens on the top.
                Tomorrow I will go for another test ride. Can't wait.
                I am not sure what year carbs I have. I would post a pic but that's something I haven't figured out yet.
                81 XS11
                • leggman1
                  • Oct 2016
                  • 130
                  • Winchester, KY
                  #38
                  I went for a 20 mile ride earlier and it runs soo much better when it's hitting on all four cylinders.
                  This bike is really a LOT different than my BMW. The Beemer is gobs of low end torque and lower rpms where the Yamaha is living at a much higher rpm range.
                  Some changes will have to be made to this bike if I am going to keep it. I am six 1 and 250 on a good day and the stepped seat and roto tiller handlebars are just too uncomfortable. If I could stretch the frame about six inches then maybe but I won't do that.
                  The bike runs great now and it is street legal after sitting for about fifteen years. I guess the PO didn't want to deal with the carb issues it had.
                  I would like to know what other xs owners have done to make these bikes ridable.
                  81 XS11
                    • 5062
                    #39
                    Highway pegs on crash bars.
                    Goldwing bars. Actually, the 81 standard bars are the best. (used both)
                    • leggman1
                      • Oct 2016
                      • 130
                      • Winchester, KY
                      #40
                      I am just not a fan of the seat. The bars are different but comfortable. I think maybe a seat from a 79 where it doesn't have such a big step might be better. It really makes you wonder what they were thinking back then. It's like one manufacturer comes up with a bad idea and everyone else has to copy that same bad idea.
                      I like the looks of the cafe racers but I could see where a 20 minute ride would kill your butt.
                      My 78 bmw had a rather flat seat from the factory and after a year or two I got a corbin seat. Much better.
                      81 XS11
                        • 8798
                        Here is the seat interchange guide...
                        • leggman1
                          • Oct 2016
                          • 130
                          • Winchester, KY
                          #42
                          Phil, You are a wealth of information. I like the 79 seat much better than the factory king/queen seat.
                          81 XS11
                          • leggman1
                            • Oct 2016
                            • 130
                            • Winchester, KY
                            #43
                            I think I got the photos thing working
                            Carbs
                            81 XS11
