1981 xs1100 running rough at low rpm
  • leggman1
    • Oct 2016
    • 130
    • Winchester, KY
    81 XS11
    • leggman1
      • Oct 2016
      • 130
      • Winchester, KY
      Also I have a question about the float height. I can kinda see that they are all slightly different. What should the float height be. ?
      In removing the main jets and tubes I kinda broke one of the small washers that goes between the main jet and the tube. Is this a part that is available somewhere???
      Thanks... Dave
      81 XS11
        Thanks... Dave
        23mm....and floats NEED to be all the same setting. If keeping the bike you seriously need to get a manual on bike.
        • leggman1
          • Oct 2016
          • 130
          • Winchester, KY
          Thanks and I am looking for a manual
          81 XS11
            • 5062
            Thanks... Dave
            I am confused. Are you talking about breaking a metal washer?
              • 5062
              Well, the washer has to fit into the recess and the diameter of main jet. If thickness can not be matched at your hardware store, it might not be a big problem. The fuel will still be metered by the jet even if the jet is submerged a little more than normal below the liquid surface.
              • leggman1
                • Oct 2016
                • 130
                • Winchester, KY
                I am assuming it was metal. It is now in two pieces and I could try to put it back in the recess and make it work but I do have some brass round stock and could turn another easily. It is the washer that goes between the main jet and the emulsion tube.
                I am still wondering if I should drill out a passage on #3 carb.
                81 XS11
                  • 5062
                  I didn't think you could mate older carbs and newer carbs on the same rail. One thing is for sure, you don't have 81 carbs. I know that 80s had some "morphedite" carbs where they had a passage between the main jet bore and the pilot bore, and used rubber plugs on the pilot bore, but that is the extent of my knowledge on that! I couldn't open the links for pictures on this ipad, sorry. I would be reluctant to drill the passage...
                  • leggman1
                    • Oct 2016
                    • 130
                    • Winchester, KY
                    Trying to post photos
                    https://www.amazon.com/photos/all/ga...os&pageIndex=0
                    81 XS11
                    • leggman1
                      • Oct 2016
                      • 130
                      • Winchester, KY
                      trying again
                      81 XS11
                        • 5062
                        Now I am on my laptop. The amazon photo gallery did not open your pix for me. Maybe you can see them because it is your folder. I cannot.
                        • leggman1
                          • Oct 2016
                          • 130
                          • Winchester, KY
                          It's alive (again)
                          I cleaned everything and put the carbs back together leaving the rubber plug out of the #3 carb (the one with no shared passage).
                          I installed the carbs back on the bike and hooked up a dummy gas tank.
                          It runs as one aussie you tube poster quoted "Like a dog shot in the arse"
                          It started right up and has a ton of power through ALL the rpm range. I still have to put the tank and seat back on but it runs so much better than it did before I am sure it's right.
                          This forum rocks.
                          Thanks to all who replied.
                          Dave
                          81 XS11
                            • 8796
                            That is good news, and now we know it can be done, mixing the two types of later carbs on the same rack.
                            07 Triumph Tiger 1050
                              • 5062
                              All 4 of his carbs have the 4 holes around the inlet bell and yet 3 of them had the shared passage between the main and pilot bore. He had at least 3 of the transitional carbs from the early 80 models. Carb No.3 had no passage. For any of the members out there, he did not mix the 78/79 carbs with later model carbs. I just wanted to make that clear.
                              • leggman1
                                • Oct 2016
                                • 130
                                • Winchester, KY
                                I still haven't had a chance for a good test run because as soon as I put the new tags on it the rain started. I can't say it is totally right but it is running a whole lot better than it did.
                                I am sure the carbs need synced and probably the air screws adjusted. When I put it back together I went 1-3/4 turns out on all four screws. I guess I could go for a short ride tomorrow and pull the plugs for a look see. That should tell me if I am rich or lean.
                                I REALLY do appreciate the help I received on this forum.
                                Dave
                                81 XS11
