clicking noise when coming to stop
  • Blank Slate
    • Nov 2013
    • 392
    • Ottawa, Ontario, Canada
    it's more than a sound, I can feel the bike lugging and clicking when I am coming to a stop in first gear. what is that all about?
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    • 9980
    Pull the clutch handle in.....
    Just being me.
    Where is it coming from? Engine, front wheel? Rear wheel? Radio?
      Likely just slack in the drive-train, or carbs should be synced, or refer to BA80's post #2.
      • Ken Talbot
        • 4251
        • Revelstoke, BC
        Check out some previous discussions on this subject here:
        Ken Talbot
          http://xs11.com/forum/showthread.php...t=click+spline
          Good to see your still just "checked out" Ken.
          • Blank Slate
            • Nov 2013
            • 392
            nope not a click in the wheel. its more engine /clutch sound. like if i am going 40 mph and need to stop at a red light, ill go down to first gear and right when the bike is about to stop ill feel/hear click click click click click. bike idles nice and runs geat so im mystified
            Frame: 79 XS1100S
            Engine: 81 XS1100S
            Carbs: 78-79 BS34
            Gf bike: 78 XS650S
            Carbs: 70-79 BS38
              • 2083
              Got a nail or screw in your tire ?
              Have the wheel bearings been lubed ?
              Is the U-Joint on its way out ?
              • Blank Slate
                • Nov 2013
                • 392
                Shming,
                no /yes / what the hell is a u-joint?
                ill take a video of the issue. to me its clutch /transmission. what problems could develop if the oil level is too low? like i said in another thread, i cant see the oil level in my glass and back when i had an oil leak i simply topped up what i thought i lost in oil to keep it from going too low
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                  Blank Slate,
                  I thik you should , while ion the side stand, pull the clutch cover and see if the clutch assembly is all tight and not rubbing the inside of the cover. And clean the glass viewing port. Some clean oil on a rag will most likely remove the dirt.
                  U joints are in the drive shaft. one under the rubber bellows. be careful pushing it out of the way as the rubber is brittle? or atleast easily damaged after all these years.
                    • 1566
                    What about coming to a stop in 2nd?
                    In 2nd with motor off?
                    In 1st with motor off?
                    In neutral with motor running?
                    In neutral with motor off?
                    Need to isolate the problem a bit more. Heck, even to a stop in 3rd gear clutch in. What's happening. More info would help. +1 on maybe U-joint or Clutch or even something else. Sound coming from engine area left or right in front of rider or maybe middle drive below you. So nothing buck or click while in acceleration mode? Bike coasts fine in neutral at 10 mph with motor off, no noises then or while coming to a stop?
                    • Blank Slate
                      • Nov 2013
                      • 392
                      since i cant take a video while im riding, i have a better description of this "clicking noise". it's less a clicking noise than it is a feeling that the bike is going to stall when i slow to a stop, but it doesnt.
                      anyone know what im talking about?
                      Frame: 79 XS1100S
                      Engine: 81 XS1100S
                      Carbs: 78-79 BS34
                      Gf bike: 78 XS650S
                      Carbs: 70-79 BS38
                      • Blank Slate
                        • Nov 2013
                        • 392
                        side note: this bike is a beast. went for a ride today and when i open the throttle it's like a bullet out of a barrel
                        Frame: 79 XS1100S
                        Engine: 81 XS1100S
                        Carbs: 78-79 BS34
                        Gf bike: 78 XS650S
                        Carbs: 70-79 BS38
                          • 5062
                          Good you you friend! It seems as if the cush drive may be causing it. Just ride the thing!
                            • 7765
                            Try one thing for me. As you come to a stop, from about 30, put the bike in neutral, clutch out, and use just the front brakes. If you want, kill the engine so you can hear the noise easier. Move your head left and right to see what side the noise is coming from. Right side is clutch, Left side is probably U-joint.
                            U-joint IS a replacement part that is easy to find! I'm on holiday, so I don't have the part number handy but it is used in Toyota and Nissan cars.
                            • mack
                              • 2411
                              • Ontario, Canada
                              Valves
                              could be he's hearing the valves. I re-shimmed them to the upper limits so it should be noisy. Without the wind they may seem louder. Do what Ray suggested Pablo in an empty parking lot and leave your helmet off so you can hear better.
                              mack
                              79 XS 1100 SF Special
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              https://youtu.be/wB5Jfbp6SUc
                              https://youtu.be/RaI3WYHSuWA
                              Frankford, Ont, Canada
                              613-398-6186
