Need ign. help
    Originally posted by 3Phase
    Now that's a great mod', who knew the contact plates would interchange!
    Sorry, but actually I did in 2000 when I needed to replace mine. I just swapped out the guts in the switch itself because I wasn't too impressed with the thickness/gauge of the wires of the NEW switch.
      Oops... you know, I had completely forgotten about that, T.C.
      So it's held up for seven years, even with the different contact lengths? Right on!
      Don, the rear brake seal kit is available from Yamaha for about $40:-
      Partzilla / Home / OEM Parts / Yamaha / Motorcycle / 1981 / XS1100LH / REAR BRAKE CALIPER:
      #6 CALIPER SEAL KIT 2G2-W0047-00-00 $42.92 1 ea.
      S. C. I. has a 304 stainless piston with the seals for about $40:-
      YAMAHA FRONT BRAKE CALIPER PISTON AND SEAL KIT
      Approx 43mm diameter
      Part#: Piston7+16055 Replaces OEM# 2G2-W0057-00-00
      • spectra
        • Aug 2017
        • 113
        • Vancouver, WA
        Also remember just because its sticking doesn't mean it needs a rebuild......that little hole in there may be plugged and just need cleaned out in the rear master.
        I have read a few posts on sticky brakes and most of the time its that little hole that allows the relief when you let off the brakes.
        Do the brakes leak anywhere?
        79 SF
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          Cleaned the caliper through out, really crusty, while waiting for a new seal kit thought I'd try it. No leaks on the bench with a front MC it pumped out about an 1/8" then the MC stopped pumping. Spent hours before I figured that, then hooked a known working caliper to it and it would not pump up either. Wasted about a bottle and a half DOT3 then realized
          THINGS HAPPEN IN 3s, thought I already had my 3
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
            • 7609
            All it takes is a small air bubble in the wrong place! IF you have the HF Vacuum hand pump, us it to get the air out of ALL the lines and then try again. DO NOT LET THE LEVEL GO DOWN TOO LOW in the reservoir or you have to start all over again.
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              Double checked for air even cracked the banjo on the MC no air ?
              Next put it back on the bike where it belongs and do this again then again when the kit shows up
              76 XS650 C ROADSTER
              80 XS 1100 SG
