above is a link to the wiring diagram for an F model.
On the top right to the left of the fuse block is something called the Terminal assembly. What is it and where could it be found?
I believe that is the auxiliary terminals. It should be below and to the left of the fuse panel.
A small black panel with 2 screw type terminals.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ
โ Albert Einstein
