An observation on shifting the XS1100
  • ThrottleJunky
    • Jan 2011
    • 183
    • PNW
    I have to shift it like I mean it. It's a totally different feel than any other bike I've ever ridden, though I'm primarily a dirt biker. I sheepishly have to admit that I've missed a few shifts, and my goal is to not do that anymore. At first, I was too light on the 1-2 shift, ending in neutral. Also, I missed a 3-4 once that left me in some weird neutral area that I was not happy with myself about.
    Yesterday, riding her around a bit, I did not miss a single shift. DELIBERATE is the word, and I'm very conscious of it now. I hope it becomes second nature. I don't want to hurt this transmission which, after reading a few things here, makes me want to be extra careful. She doesn't pop out of gear at all.
    1980 XS1100G. Work in progress.
    1980 XS1100G. 2nd work in progress.
  • Tenorman
    • Oct 2013
    • 70
    • Butler, Penn.
    You are correct....
    ThrottleJunky,
    These bikes shift like an old tractor!
    After buying new and used gears to repair my transmission, I also shift quite gently...
    I've also had a bit of a "little kick" on my left big toe going from third to fourth gear...I think that may be normal, but let some others chime in...
    Have fun and keep the rubber side down...
    Tenorman
    Bikes that I have owned and enjoyed...
    1964 Allstate 250
    1970 Yamaha DT1
    1959 Mobylette
    1970 Yamaha JT1
    1995 Suzuki 80
    1978 Yamaha XS650
    1980 Yamaha XS1100LG
    2005 BMW R1150R
    • Old Red
      • Jul 2012
      • 290
      • Greenville, NC
      A good firm shift works best on these bikes. If you get just a little lazy shifting, you will find a false neutral.
      80SG, 81SH, 80 standard parts bike, 81SH parts bike
      and new to me 78 standard dresser
        • 2038
        Yep, you have to shift like you mean it.
        My most common problem is missing 4th gear when I am really getting on it. I end up in that false neutral, and if I try to put it back into 4th gear, it does a horrible grinding on the gears; seems better to slow down and shift down.
        I moved the 2nd gear washer on my SF, and it is more finicky going into 4th gear than my SG transmission, which has the original washer location.
        • mack
          • 2411
          • Ontario, Canada
          nope
          they can and will shift like an automatic if your skilled. Preload the shifter and your gold, get lazy and these bikes will eat you. If your actually riding one, they handle like dragsters. Bullet fast in a straight line but suspect on the first curve, be cool and learn the bike. They are sierra hotel all the way but they aren't for armatures.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • myac455
            • Jul 2017
            • 72
            • Mayer, AZ
            I don't have any personal experience with these on the road yet, but I did observe some of the weirdness while I was bench testing mine the other day.
            Sounds like one might want to drop the shifter down one more notch to get a good amount of leverage on it? Yes/ no?
            Mark Yac
            79 Former Police XS 1100
            Real life never quite adds up
              Actually, for nice shifting on your part, wear a good boot......no tenny-runners.
              • dbbrian
                • May 2016
                • 596
                • Stratford, Ontario, Canada
                Yep, Russian Tractor
                Someone on here said something about it shifting like a Russian Tractor, and when she bangs into gear that saying often comes to my mind.
                When I drop her into first gear from neutral, and then pull away and make the very deliberate upshift past neutral to second, I'm pretty sure I get more heads turning than the Harley owners that blip the throttle at the intersection
                I went from a sewing machine-like CB350Four to this beast. I thought something was wrong, but like you are now reading, the good people here will set your mind at ease.
                For me, its now part of the grand experience of the XS, and I think you'll soon learn to love it too
                  • 7817
                  Mine has the washer move. I did it when I replaced the gears. It shifts like butter.
                  • dbbrian
                    • May 2016
                    • 596
                    No WAY! Really?
                    You ruined it man
                      Hey TJ,
                      Like Mark Yac said in his other clutch thread, rotating the shift lever down another shaft spline/tooth might also help in giving you more leverage for upshifting.
                      As was said, Preloading/putting your foot into shift position with some pressure against the lever also helps, but also USING the clutch, and briefly letting off of the throttle also will help the gears to spool down a little to allow them to mesh better before putting throttle load back on them. These are square cut dogs/slots, they are not syncromesh gears, and so these little tricks/techniques aid in making the shifting process smoother and more successful. Many of us have gotten so good at the throttle blip that we CAN upshift WITHOUT using the clutch, but it's easier on the gears when you do use it.
                      Now for trying to prevent damage when shifting from a stand still neutral into 1st, one technique is the HOLD the lever in for several seconds to allow the gears to slow down their spinning before making the "CLUNK" shift into 1st. The other technique is to actually shut OFF the engine, shift into 1st, and then Restart holding the clutch, and then take off. 3rd is while coming to a stop, downshifting into 1st while moving, and then just leaving it there holding the clutch lever while waiting for the light, etc.! And when decelerating and downshifting, blipping the throttle a bit higher also helps to mesh the gear speeding it up a bit before downshifting.
                        • 1566
                        Yep, I've ridden his 11. Fantastic machine. In fact, a few different times. He's absolutely right ..........
                        Shifts like hot knife in butter.
                        I always thought Phil's Addie shifted very well. So does my E.
                        • SteveO
                          • Aug 2002
                          • 91
                          • New Jersey
                          Is have experienced that "limbo neutral" many times through the years; mostly when I shift too softly; and sometimes when I rode in sneakers (my bad). Since now I wear hard riding shoes and pay more attention to what I am doing, it does not happen anymore.
                          1979 XS1100 Special - On the Road https://xs11.club/core/images/smilies/smile.png
                          1973 RD350 - In the Shed https://xs11.club/core/images/smilies/frown.png
                            • 5058
                            I think it is a good idea to slow considerably before trying to recover from a false neutral...
                              • 6762
                              My method for shifting into first..for many yrs...as I am slowing down to come to a stop...I downshift into 1st at 5mph..no clunk..but then i will sit there holding in the clutch..As I have aged the arthritis sets in and holding clutches aint as easy or painless..still less punishing on the transmission..I never liked the clunky gears..never had them buttery smooth either...
                              persona non grata
