An observation on shifting the XS1100
    Mine shifts just fine. I don't even use the clutch on upshifts. The power shift takes a little practice to perfect but once you do it shifts smooth.
    Down shifting requires the use of the clutch however.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Rev
      I've found that when downshifting giving the engine a little blip of the throttle seems to get the gears to trans from engine going as fast as the lower gear I'm shifting into.
      When I start the bike cold I do it in neutral let it warm up and if in a hurry before it's warmed but oil circulated turn it off put it in gear and start it again so I don't get that big KUR-CHUNK. This also makes sure the clutch is freed up and not dragging. If I put it in gear while choke (enrichener) is on and the bike still reving, clutch still dragging I will get a most bone chilling KLANK AND LURCH. I keep a finger on the front brake lever to avoid the lurch always when starting in gear.
      If the clutch is adjusted right and the engine is warm and reving 1000-1100 rpm. it snicks into gear sweet as can be, such as dealing with long light, trains and such hold ups.
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
